00 V70XC Car drifts to left after alignment
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
abscate wrote:...Probably a hundred ways to simulate a load in a car without getting in the customers face about it.
Well, we tried getting a hundred dogs in that car but they would not stay put... :lol:
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
instarx
Year and Model: XC70 T6 2011
Has thanked: 1 time
Post by instarx »
abscate wrote:Make sure the ball joint is into the LCA all the way. Its possible to put the bolt in without picking up the flat on the joint. Eyeball the balljoints and make sure they look the same
This is really, really dangerous, btw.
Im grasping at straws here, though. Bent frame or sub-frame?
No, I can't believe it anything is bent. No accidents ever. And I'm just a normal guy, 200lbs (well a little overweight lol)
Yes, it is dangerous. Drifting off the road is one thing, but into the opposing lane is another. I'll order new control arms tonight for both sides. Actually, what I think I'll do first is go get that alignment double-checked.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
Has thanked: 2200 times
Been thanked: 1852 times
Check the brakes are not binding, in particular the rear calipers. The AWD have a more complex rear suspension, so also check the bushes in the 4 stays bars (the cross stays on the rear behind the sub-frame, also check the cam adjuster bolts on the inside bush as they can shear). These cross stays adjust the rear toe in/out.
Check the upper bush were the upper control arm connects to the hub as they can wear which allows the car to steer from the rear.
Also check the lower control arm bushes, particularly the inner one that is pressed into the sub-frame as this was the only one that was really bad on my car during strip down.
The stays that have the front mount just in front of the rear jacking point do also fail with age and can be hard to see as the large washers on them hide the rubber.
2 notes on this. If the front bushes are bad on this stay, buy the bush and the mount (only $5 difference in price at Tasca) as the bush is on back order. There may be a poly bush from a 240 that can be used in this location but I would need to look into that. There was a guy called Big Will on V70r website that listed all the bushes.
Also keep the rear larger washer from the mount as it is obsolete. The front one with the smaller hole in it is available, you could buy 4 and drill the hole on 2 out to the larger size.
instarx
Has thanked: 1 time
Post by instarx »
I just got a call from the alignment shop. Seems they aligned another car yesterday and it was brought back with exactly the same problem - drifting to the left.
It turns out their alignment machine was out of calibration.
Thanks for all your help, guys! Now, I have to send all those parts back.
UPDATE: It was out of alignment and they corrected it, but it still drifts left. A second shop verified the aligment is correct. So I'm back to replacing the LCAs next week.
2011 XC60 - sold
regent
Post by regent »
I hope you've got the Lemforder LCAs (or at least Meyle HD) for her. I would to the BJs as well while I am at it. They will soon be (past)due if not already
2015 BMW 335i
Big Will
Year and Model: 1998 V70 AWD
Post by Big Will »
Any chance that the tech forgot to center the steering wheel before doing the alignment?
98 V70 AWD - M58 Gearbox - Beüst custome tune, 20T turbo w/angled exhaust housing, Green injectors, Öhlins Roadholding Suspension, B MAC Built Engine
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
instarx wrote:I just got a call from the alignment shop. Seems they aligned another car yesterday and it was brought back with exactly the same problem - drifting to the left.
As above, how is the steering wheel when driving on highway? Is it spot at the center?
instarx
Has thanked: 1 time
Post by instarx »
regent wrote:I hope you've got the Lemforder LCAs (or at least Meyle HD) for her. I would to the BJs as well while I am at it. They will soon be (past)due if not already
Meyle. I thought the ball joint and LCA came as an assembly.
Can't afford the Lemforder - this is a 15 year old car after all.
Steering wheel is straight, I'm not steering it left. If I let go of the wheel it will be over the yellow line in 5-10 seconds.
2011 XC60 - sold
dosbricks
Been thanked: 4 times
Post by dosbricks »
I tried the Meyle HDs on the S70. You are correct, the ball joint is included. The bushings must be pretty tough because we found the ride to be rather harsh for the the first couple of weeks (new struts also breaking in). Then it gradually mellowed out and is pretty decent now with good control, but the dash was squeaking at every rough place in the road at first. Lemforders just make the car feel like it's new again.
Let us know the resolution of this because I have a slight drift to the left on my wagon. After reading this thread, I'll try the tire swap.
dang5002
Year and Model: S70 AWD 99
Post by dang5002 »
I had the same problem when I put on new tires. Alignment was spot on, too. Found it to be a bad tire. The tire shop said it was called radial pull. They installed a new tire and the problem was gone.
