Feel free to remove the clip and keep it as a souvenir - it just gets in the way. There are probably torque values somewhere, but "good and tight", will do - don't Hulk Hogan them down.
A 1/4" swivel joint will help you immensely with the left and right lower intake manifold bolts. Should be able to pick one up at Sears or what have you.
Double-check all of your turbo hoses too - hopefully you'll have it back together and working well!
By chance, did you remove the injector/rail when you swung the intake manifold out of the way? It's possible one of the seals there is loose and I imagine that would make some sort of popping noise.
Popping from manifold after PCV change
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
'98 S70 T5
2016 Chevy Cruze Premier
You guys are great. Really appreciate the help. Got everything back together and the popping is gone and the exhaust looks good. Smoke still comes from dipstick and still a small ampount of pressure from oil fill opening (glove test). Is it possible the Mass Airflow Sensor is bad and causing this? When I unclip the the sensor it seems to run a bit better.
- Has thanked: 312 times
- Been thanked: 818 times
MAF could be related to it not running so well, but not to positive crankcase pressure (i.e. not to the glove inflating).
What brand is the MAF, is it a Bosch? For a 98, all other brands are very spotty on their reliability. The car shouldn't run better with the MAF unplugged unless the MAF is bad, is the difference really notable? How about when you drive around, is it still better unplugged?
jblackburn
Give it a quick rev by tugging on the throttle cable and see if it still smokes at a higher RPM. If the smoke up the dipstick disappears and glove deflates, your PCV system is good to go.
My car has eaten several MAF sensors. I think it's on #3 now.
'98 S70 T5
It definitely runs better with the MAF disconnected. Hard to tell when driving but it will stall at start up with it connected. I'm going to try to clean it tomorrow. Still not sure where the remaining Crank Case Pressure is coming from. I got this car from a friend and it was severely neglected. After changing the PCV and the oil/filter its running a lot better. Would like to find out where the remaining pressure is coming from though. Is it possible that after completing the PCV and oil/filter the pressure will continue to return to a normal level? Also, a auto store clerk said sea foam in the vacuum lines may help. Have you had any experience or luck using sea foam?
Seafoam is debated a lot, do a search there are a lot of posts about it here. I don't use it anymore.
What brand is the MAF? It really matters.
Regardless, sounds like it needs replacing. The parts stores sell a lot of MAF cleaner because the sensors are expensive but it almost never works, for the record. Unless you can see oil or other residue/debris on it, cleaning is unlikely to help.
jblackburn
Vacuum in the PCV system comes from 2 different places in turbocharged engines. At idle, it's coming from that tiny vacuum line on the side of the intake manifold. When revved up, it's coming from the intake side of the turbocharger. That's why I suggested giving it a quick rev to see if the smoke up the dipstick disappears and glove deflates. If that happens at higher than 1000 RPM, you're good - no need to worry about the PCV system anymore, and it is working as intended. A little blow-by at idle means nothing more than the rings are a little bit worn, to be expected at this age.
'98 S70 T5
I tested it at highr rpm's and it seemed ok. Unfortunatley I went out this afternoon and the key will not turn in the ignition now. About at the end of my rope with this thing. Im gonna play aroubnd with it for a bit and if nothing comes around I'm done spend ing money on it already. Thanks for all the help.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
When you did the PCV system, did you clean the block holes out real good?
Also, did you do a compression test prior to diving in? A warn motor (rings) will produce head pressure/blowby.
- 908 Views
Last post by jonesg
- 2724 Views
Last post by SuperHerman
- 908 Views
Last post by BEJinFbk
- 30 Replies
- 9473 Views
Last post by Ben850
- 1030 Views
Last post by mika
