VVIS controller 850
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
search the database for post from user ben850, he has/had a controller on one of his cars, and the write-up was in here. Check the performance/mods sections
Current Volvos:
- Has thanked: 312 times
- Been thanked: 818 times
He's right, ben850 has a ton of posts about this.
https://www.matthewsvolvosite.com/forums ... hp?t=52574
https://www.matthewsvolvosite.com/forums ... 1&start=42
etc.
etc.
Interesting. Great to get info from an expert.
precopster
- Year and Model: Lots
- Been thanked: 128 times
Can he supply you with the circuit details?
I think the mod was pretty effective From memory the factory setup opens the 2nd stage at 4,000 revs and can be a little flat in mid range.
Razorx's setup broughr that shift point down and gave greater midrange torque.
Perhaps something simpler like extra vacuum at the solenoid will do the trick or a vacuum pump activated by a relay at 3,000 tevs (you'll still need a circuit board)
Edit: just realised that you don't need this now. Great info
jantt
- Year and Model: C70 2000
- Been thanked: 2 times
Did two other things this morning :
1. Disconnected the tube from exhurst manifold to airfilter and screw the plate that allows hot air into filter closed, so only cold air comes in.
2. Changed the intake tube that leads air into filter with a bigger 76 mm.
These two things gave better response.
Now that I got more and colder air into the engine would bigger injectors then help if the old ones has reached their limit ?
Different injectors make zero difference unless the ECU is reprogrammed to change the fuel delivery. And there is no tuning that I know of for NA ECUs.
Since you live in the far north, be careful with that airbox mod if you do long distance driving, rarely it can result in a frozen throttle body. If you do short drives that frequently change the throttle position then there is no risk at all.
jantt
I only drive short trips (normaly less than 20 miles - in the summer some times longer).
I still have all the old parts and can change it back in less than 15 min.
Just wonder if the standard injectors are limit to deliver a small amount of fuel and then bigger ones would do more.
- 2218 Views
Last post by precopster
- 13 Replies
- 7084 Views
- 21 Replies
- 6655 Views
Last post by Denversm
- 18 Replies
- 2458 Views
Last post by cheap850
- 2492 Views
Last post by bigty69
