I tried 5 or 6 diff scanners to read volvo extended info, vida is the only way to do it correctly
Give me an old laptop and I can help you setup software, interface is about $75
I can even take an old laptop and setup for you
PM me what you want, once setup is can do a lot all the way to current models
I have even turn off srs light on cars I looked at for sale
Scan tools - confusing amount... which work?
jenkinskg
- Year and Model: 04 c70 hpt 98 s70 xc
- Has thanked: 1 time
So I just configured a virtual hard drive with full windows 7 and functioning vida software.
What does this mean?
It means a copy of this file put onto another laptop can result in the ability to have 2 seperate copies of windows, the Vida copy setup just to use for vida.
This allows you to use same hardware, diff software using boot to vhd file.
I will be putting this on my windows 10 fast machine, then I can retire the older slower machine for emergency or to sell as is.
The vida copy seems to need updates turned off, since some updates make vida not work, especially IE and java updates
Let me know if you need help, I can help with a flash drive with file on it
2004 c70 2.3HPT, s60 2.5T
jenkinskg
Just bought this one autel md802
https://www.amazon.com/gp/product/B0090 ... UTF8&psc=1
Does more than any other scanner, much easier than vida, I have vida
This told me I had a stored code about my top stopping before it was retracted and told me my outside temp was NG
it also showed immobilizer codes
awsome scanner, free updates on software until 2018, buy on amazon, then try and return if you don't like it, or if it solves the issue
jenkinskg
Just got this, able to do full scan on car, extremely good
So far it sees
Trans status which solenoid it on or off while driving, wheel sensor velocity all at once graphed, wheel temp, to check if brakes are hanging
It saw that my top on c70 stopped and saw the stored codes days afterwards
I saw outside temp sensor issue, still not resolved, but it saw I put a resistor in it to adjust it.
It is also able to reset service lights, srs abs and it even thinks my seatbelt switch if intermittent.
I was very impressed at what it can do so far, and was able to update to newest software in a few minutes.
it even saves results and prints them for you.
Best part, it boots in 10 seconds and can stay on if car is cycled or part is swapped!!!
So far it sees
jenkinskg sounds like this scanner is pretty good, just to be sure about it does read the codes related to the convertible top? I just picked up a 2000 C70 and looking for a scan tool to help me work out all the little issues.
Thanks
Bob
Thanks
Bob
jenkinskg
I paid $175 for the all system one, so far it has read more in scan mode than I ever expected, and twice as fast as vida.
Will not do activations like vida, but will point you in correct direction, graphs wheel speed sensors!
told me outside temp was NG
jenkinskg
paid less than 175 on amazon for my md802Liliflower wrote:less than ~$300?
original Autel MD802 full-boat +datastream $259, update online (with serial number and official site upgradeable)
http://www.obd365.com/wholesale/maxidia ... ystem.html
If you have a delicate XP laptop, then go for VIDA DiCE unit, less than $100
http://www.obd365.com/wholesale/volvo-v ... rsion.html
not 100% sure they do Volvo worldwide
Works really well
enotslim
- Year and Model: 2004 XC70
- Has thanked: 71 times
- Been thanked: 16 times
Trying to connect Autel MaxiDiag Elite 802 via VMWare Fusion 8.5.3 with no luck. Haven't figured out how to "see it" as a usb device from either Windows 7 32 bit or 64 bit running in VMWare. And when the device is connected to usb at start-up, it entirely blocks booting up before the password entry step. Haven't tried XP in VMWare.
The scanner doesn't show up as a usb device, even an unrecognized device w/o drivers, in Mac OS, so maybe it's pointless to hope it might be recognized by a virtual machine.
Any suggestions?
Any suggestions?
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
- 14 Replies
- 3369 Views
Last post by esl_97_850_T5
- 14 Replies
- 3445 Views
Last post by jenkinskg
- 561 Views
Last post by wizechatmgr
- 2744 Views
Last post by matthew1
- 12 Replies
- 2126 Views
Last post by Sommerfeldt
