Traveler brand oil from Tractor Store.
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
More info: Warren makes it. They also make the Walmart Supertech brand.
http://www.wd-wpp.com/tsc/faq.htm
Typically I use Castrol GTX and change it at 2500 to 3000 miles.
So whats better in the long run??? Synthetic oil and doing longer oil changes 5000 to 8000 or the more frequent changes (even with cheap oil?
My 98 V70 and 96 850 both have 230K and run very strong. Both only use Premium Gas.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
instarx
Year and Model: XC70 T6 2011
Has thanked: 1 time
Post by instarx »
abscate wrote:What specifications does the oil claim to meet? Check your owners manual to see what's required got your car, as a first step.
Deciding if you believe the spec would. Be step two, to frugality nirvana.
I used to work for Shell Oil and they would bottle various house brands of oil using their filling machines. The difference? They changed the labels on the bottles running through the filling machine.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
LesRED850R
Year and Model: V70T 1998
Post by LesRED850R »
What makes good oil is the base that it's developed from.
Sure it's the cheap or affordable one you go for and see " no problems" but good quality base oil manufacturers (Penrite,Redline,Amsoil) always test at near to new at the usual time of oil change you would change your crappy kmart oil at which is seriously degraded and the engine is worn a bit. . Are you serious about looking after a motor that costs you wages. Time off work. Dollars to run another vehicle for downtime. High cost of parts and labour. For what, to save a few dollars an oil change, it's a no brainer (or, those with no brains saying it's fine with utter garbage oil, they the no brains....)
Cheers! LesM.
amblerman
Year and Model: 1999 s70
Has thanked: 2 times
Been thanked: 70 times
Post by amblerman »
cuhfs wrote: 10 Apr 2016, 16:20 More info: Warren makes it. They also make the Walmart Supertech brand.
Warren makes a lot of store brand oils (costco/kirkland oil, Amazon oil, etc). Most likely they are all the same with different labels.
And most importantly, carry the most modern SP (or SN Plus if you find an older bottle) specs.
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
With the original post only going back to 2016, do oil threads go back before the origin of the internet?
I wonder if prior to internal combustion engines people debated about horse feed.
08 C702.5T (sold)
The non-Swedes:
amblerman
Post by amblerman »
FlyingVolvo wrote: 09 Apr 2016, 20:23 That stuff is dirt cheap and looks like garbage to me. You don't need to spend a ton of money for boutique fancy oil, but seriously, at least go with some Mobil 1 or something. You can get those 5 quart jugs for a great price at Walmart (~$25?). Don't get oil from auto stores. I'm not Walmart fan, but I will go there for motor oil. That cheap oil probably has few if any additives. Oil is the one thing that keeps your engine from shelling itself, definitely not the best place to go super cheap on.
Please don't use that stuff.
The oil in question meets GF-6 and SP. Those are both current specs. I wouldn't label it as "garbage oil".
I do realize it's not a well known brand name and I realize that in many respects in life you do get what you pay for. Tractor Supply doesn't actually make the oil. Like most private label brands it's blended by someone and unless the bottle is lying, meets current, up to date specs.
I fully agree that there are differences in oils. But I suspect ( i have no means to really test this) that those differences come into play on extended drain intervals, when using boutique oils (the top of the line Redline oils for example), having some high HP/turbo car that sees a lot of strain, and whether or not you are looking for an oil that meets some particular characteristic (cleaning ability or higher Zinc levels for older cars).
I am not convinced those factors come into play when using a drain interval of 3-5K. especially on my non-turbo.
I personally have no problem using an oil that meets the current spec of SP (unless company was lying) in my 1999 that called for the ancient SG spec. :-)
-A
amblerman
Post by amblerman »
Krons wrote: 11 May 2023, 08:57 With the original post only going back to 2016, do oil threads go back before the origin of the internet?
oh my gosh.
I didn't even notice the date on the original post. :-)
I thought a post about Traveller oil from Tractor Supply showed up because they have some of their oils on clearance right now (I missed out on sale).
I just spent 30 mins trying to find out who actually makes it (It may have been made by different people over the years) for a thread that is 7 years old. :-)
Has thanked: 1609 times
Been thanked: 4065 times
$30 for Castrol Synthetic, 7500 mile interval
Oil cost 0.5 cpm
debating costs on the 0.1cpm scale doesn't make a lot of sense.
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
I love when old threads get resurrected. Oil will always be a never-ending debate.
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
Another ancient thread creeks back to life.
None of the big retailers can afford taking the chance on selling purposely mislabeled oil; it's hard to imagine any packagers going along with a scam anyway. Our forced-induction cars came from Mother Göteborg with synthetic, and since I know for a fact I'm not smarter than the building full of engineers who designed the car, I stick with that, in the weight specified in the owners manual. The price point between regular Dino squeeze and synthetic isn't enough to buy a six pack, so why bother.
The real geekfest is over on bobistheoilguy - but fair warning, don't go too far down that rabbit hole if you are easily influenced by pseudo-science psychobabble. The best information I've seen published recently is by a petrochemical engineer in Hot Rod.
