Just my .02 cents, I had to do the rack on my 93 850 and I know that's a complete different car but I went with a duralast rack, it was the cheapest, free shipping to store in a day, and lifetime warranty...
I did it in the garage and that was terrible so I feel sorry if your gonna have to do it on a gravel driveway, the creeper helped alot
Also if while your in there and your pressure and return lines look like they may need replacing I'd suggest doing them at the same time, the angle I had to put the rack at to get them to attach without cross threading would be impossible while attached and there is just no room to try and pull on the lines while attaching. It sucks.
And don't forget the sway bar going back in like I did and have to re torque the subframe, its a torque angle spec and its a bear to do it nothing like having to do something three times...
1999 Volvo V70na Steering rack woes...
paredown
- Year and Model: 1999 V70
- Been thanked: 2 times
Doh! Duplicate post!!
Oh, I might as well use it to report that Jac's quoted me $266.99 + $150 core on a rebuilt SMI rack.
My local independent (who does Volvo) quoted me 3 hrs for replacement (plus the alignment and flush) and it was around $600 all in.
He did get a little snarky though--since it would be my part, they would charge me labor up front to put in, and would charge me labor if it needed to be taken out if there were a problem...
1999 na 2.4l V70 beater--donated to Habitat in running condition
paredown
Much angst on this end, but I finally decided that my '99 has the new style tank off to the side, and the SMI rack, so it should probably use the CHF style fluid. I was able to pick up the Pentosin at our local Carquest (formerly a NAPA shop--it was in the identical cans as the NAPA offering so I don't know if it was holdover stock). It was $18/qt so cheaper than Amazon.
I actually removed the p/s reservoir so I could check it for leaks & cleaned it thoroughly. I then did the drain, pump through until clean fluid was coming out the return. I used about a quart until it was pumping clean. What came out in the flush was pretty nasty. I then buttoned everything up, topped up the fluid and added the stop leak (the container treats 6 quarts, so I used about 1/6 of the bottle).
I cleaned the driver's side of the rack, so I could see if it will leak new fluid--I will check it again tomorrow to see if it has sealed up at all.
But I managed to create a problem for myself--fighting to separate the coolant and p/s reservoirs, I managed to break the connection of coolant level wire and I found a crack on the overflow return to the coolant tank. That may have been there already since I have had minor fluid loss for a time, so it looks like I will be back in there one more time to replace those.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The level sensor in the coolant tank is prone to break when the tank is lifted without disconnecting the electrical connector. The tank shouldn't leak though, only the sensor will show false alarm low level.paredown wrote:But I managed to create a problem for myself--fighting to separate the coolant and p/s reservoirs, I managed to break the connection of coolant level wire and I found a crack on the overflow return to the coolant tank. That may have been there already since I have had minor fluid loss for a time, so it looks like I will be back in there one more time to replace those.
paredown
For the life of me I could not figure out the electrical connector. Of course it didn't help that there was residual brake fluid around and on my hands so I could not get a good grip on it.oragex wrote:The level sensor in the coolant tank is prone to break when the tank is lifted without disconnecting the electrical connector. The tank shouldn't leak though, only the sensor will show false alarm low level.paredown wrote:But I managed to create a problem for myself--fighting to separate the coolant and p/s reservoirs, I managed to break the connection of coolant level wire and I found a crack on the overflow return to the coolant tank. That may have been there already since I have had minor fluid loss for a time, so it looks like I will be back in there one more time to replace those.
The leak though is on the top return line molded connector. At first I thought I hadn't clamped tight enough, but there is a small crack just at the base of the connector on the tank...
The steering feels better than before the flush and fill with new fluid--a little less 'powered' than it did before.
