Major problem, Radiator leak?
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Yet to hear of a $150 transmission line, is that original Volvo part?
The upper transmission (return) line disconnects easily from the radiator but the o-rings+clip should be replaced. The lower one is rusted where it meets the radiator but can be disconnected at the transmission end (transmission being drained).
A good aftermarket radiator should be less than $150 and a good mechanic should be able to even save the lower transmission line.
I'd look for a good garage around your area local.google.com and check for the reviews if any. Your is the kind of skimming one. Might work fine, but if he sees you are willing to pay that much, you may have the surprise of other things 'going bad'.
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
Save the money and do it yourself. It's an easy job. RobertDIY and fcp have videos on youtube. Took me 2 evenings.
1996 855 R,
2010 V70 D5,
Has thanked: 1611 times
Been thanked: 4075 times
Let's be sympathetic to those who run repair shops. They will not spend time shopping the inter webs and anchoring the price of a part at the cheapest vendor in Ulan bator and then adding their labour. Shop is getting a quote from their reliable wholesale supplier and marking up to keep the lights on
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Hello again,
The car is the v70 FWD, no turbo, Vin number says it is 2.5L.
Automatic trans.
I'll try to get a pic of the radiator hoses and fittings.
I also understand the front has to be jacked 18 inches high though. Any way to get it out the top?
Thanks.
PS78
Year and Model: 2000 S70
Has thanked: 2 times
Been thanked: 3 times
Post by PS78 »
Good old Ben from FCP got it out the top.
Always first off the line, while all the cool people are still staring at their phones.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
abscate wrote:Let's be sympathetic to those who run repair shops.
Autozone listed the radiator at $180. It's criminal for them to add on another $165. That's a 91% markup. :o
85 GLH, 367 whp
00 Insight, 72 mpg
tryingbe
Has thanked: 1 time
Post by tryingbe »
MrAl wrote: Any way to get it out the top?
Sure, but it would be way more complicated than from the bottom.
85 GLH, 367 whp
00 Insight, 72 mpg
Genuine Volvo lists at 320 USD. Thats about 33% markup. I think they will be happy to use your specified AZ radiator as long as you will pay for any extra fitment at 115 per hour.
PS78
Post by PS78 »
Are Behr or Nissens radiators a good replacement? They go for 120 and 119 respectively. Their heater cores receive plenty of praise in this forum.
I think Ive put about 40k on my Nissans radiator, replaced in 2012/3 with no problems
