2000 V70 XC AWD SE Rear Wheel Camber Issues, excessive tire inner tread wear
lous_97_850
Year and Model: 2001 V70 T5
Has thanked: 1 time
Post by lous_97_850 »
Ordered new springs and seats. Waiting for the to arrive to replace
How is the toe adjusted on the rear?
What are specs for camber and toe on the rear?
Thanks,
Lou
Has thanked: 2199 times
Been thanked: 1852 times
Don't know about the specs, but the toe out is adjusted by the inner mounting bolt on the rear cross stays (the 2 rods that run across the car behind the rear axles). If you look at the inner mounting point you will see there is an eccentric cam on the rod.
lous_97_850
Has thanked: 1 time
Ok Thanks
