AC compressor clutch doesn't engage
Volvo Kush
Year and Model: XC90 2003
Post by Volvo Kush »
I attempted the zip tie fix today and failed miserably.
There is absolutely no way to reach it from the top and there is no access panel behind the wheel either. Hell, even measuring the gap was a challenge (had to build a primitive extension for my feeler gauge.) The compressor is surrounded by frames, turbo tubes and other stuff.
I ended up partially removing the bumper cover to access the clutch plate from under the vehicle (see pictures). I started with some heat resistant medium sized zip ties. As I pushed the tip of one of them through the "ring" it closed the gap completely, even though the tip is much thinner than the tie itself. I switched to stainless steel ties (~0.28mm thick) but couldn't do it efficiently due to the lack of space and ended up bending the tie which made it extremely difficult to proceed with the installation. It took way too much time (~1.5h) and decreased the gap to only about 0.45mm. I decided to simply jam in 2 small plastic ties and cut the excess (didn't even tie them, just wanted to make it work to prove the concept), which I did to no avail. I will attempt the bread clip trick tomorrow since it was nearly impossible to blindly install the ties. Might also look into removing the windshield fluid reservoir to gain a little bit more room.
Potato camera photos here:
Has thanked: 1610 times
Been thanked: 4068 times
The P2 wagons are much harder than the P80s - I don't have an XC90 but it sounds like its the same.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Now that's a tight place. The S60 is quite a bit larger, still not easy to insert tabs. I actually cut and slide in some spark plug shims and bent them in place because once the plate rotates it will throw them right away. Just make sure the plate makes no noise or the clutch material will disappear within hours.
Volvo Kush
Volvo Kush wrote: UPDATE 1:
So today I gave the stainless steel ties another try, jammed each of them through each side of the ring spring in such way that zip tie passes under the rubber thingy *see pictures below**. Managed to reduce the gap to a tight 0.4 and 0.5mm by moving the ties a little and later on, to a tight 0.3mm by adding bread clips. Neither setup made it blow cold air again.
Frustrated, I even tried to tap (very firmly and convincingly with the engine running and A/C button on) on the clutch plate with a wooden stick to make the gap close and force the compressor to work but, surprisingly, it didn't. I also observed that the clutch plate becomes harder and harder to turn manually as I add extra zip ties, even though the gap was nowhere close to 0.3mm. Not that it was spinning freely without them but...
Anyway, as before, the only way to engage the clutch is by starting the vehicle (runs for 5-10s) or by overriding the relay with a paper clip.
Pictures: http://imgur.com/a/kJUiu
Am I doing something wrong or is this solution just not for everyone?
Is it risky to simply jam in a paper clip when I really need A/C? Is the circuit still protected by a fuse?
Volvo Kush
oragex wrote:Now that's a tight place. The S60 is quite a bit larger, still not easy to insert tabs. I actually cut and slide in some spark plug shims and bent them in place because once the plate rotates it will throw them right away. Just make sure the plate makes no noise or the clutch material will disappear within hours.
That's exactly what happened to my bread clips after I tried to loosen them up a little. I'm glad I didn't use metal plates...
oragex
Post by oragex »
Could the system be overcharged?
Basically the 'gap' has to be as small possible without the clutch to grind on the pulley when it's not engaged. Given it doesn't engage at all, assuming there is correct pressure in the system, I'd try getting an evaporator sensor from another car and swap it see what it does. This sensor is a thermistor that feels the cold air inside the evaporator and tells the compressor to engage/disengage the clutch. but normally when this sensor fails it does the opposite: it prevents the clutch from disengaging. I'd also check the wire at the compressor magneto is properly secured (it activates the clutch).
Volvo Kush
oragex wrote:Could the system be overcharged?
Hi and thanks for your reply!
I removed the wire and plugged it back in - no improvement. It's a 1 wire plug, so I guess the negative goes through the compressor body.
I located the evaporator sensor, I will try to go to some of those places that sell used S60 S80 V70 XC70 XC90 (source: https://goo.gl/UfIqAl) and ask them if I could swap their evaporator for a fee.
Volvo Kush
I had my CCM codes read!
CCM-001F air quality sensor: Signal too high
CCM-0020 air quality sensor: Signal too low
CCM-0004 compressor: Faulty signal
Screen picture here: CCM codes XC90 2003 - Album on Imgur
Where are these sensors located?
I missed this earlier. If your compressor comes on with a relay override then th e clutch gap is NOT your problem
You either have too low/ high pressure or faulty ECC signals from the ECC controller
Roger_850T
Year and Model: 854T 1995
Been thanked: 26 times
Post by Roger_850T »
I agree with abscate. If the compressor comes on when you jumper the relay, then the clutch gap is NOT your problem. (It may be that it's worn, and will need addressing at some point, but that's not the issue today.) I think you also said you swapped the relay, no difference. So, the question is why is the relay not being energized. Some thoughts:
1. It is low on refrigerant (low pressure cutout). Despite what the shop said, it may be low.
2. Too much refrigerant (high pressure cutout). Or condenser fan not working, and the pressure gets too high due to no condensing.
3. Other issue (incorrectly getting no call to turn on?)
I'll have to research what is supposed to turn it on.
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
