Video coming to a stop in drive verse neutral
https://goo.gl/photos/FRrhaBVihAqRYnnX8
2006 xc90 v8 - Rough idle in drive while on brake..
humberto103
- Year and Model: 2006 xc90 4.4
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
I have one more data point for you - today I had VIDA/DiCE hooked up to my 2005 V8, so I tracked the throttle position and engine speed while I started it. The throttle position was at ~11% for the first minute while it warmed up, then dropped to ~5.5% to ~6.0% and stayed there while it idled at ~710 rpm.
This was in Park. I didn't think to put it in drive and see what that changes.
Comparing this to what you captured, it looks like your ECU is at least commanding the throttle to a higher position in response to a lower rpm. (Yours was ~7%.)
What we don't know - is your car running low because the throttle is not responding properly, or is the throttle ok but it's running slow because of some outside influence.
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
humberto103
Looks like I'm going to have to pull the booster and investigate. I do have a vacuum line that I haven't been able to verify that runs under the fuse box.
I won't be able to get to it for about a week. Thanks again for the feed back R.
humberto103
Still having this low idle issue. Ive change out the throttle body and the brake boster with some used junkyard parts, didnt change anthing. Its a shame, 99thousand on the clock and i might just have to through in the towel.
Took some video that shows the transmission shift IND mode - lock up function
https://goo.gl/photos/MLaduiebp7CJMidF9
I did capture some video of this sound that cant wrap my head around
https://goo.gl/photos/xrfLyUE3SSnrJK2GA
Watchen the first vid you can almost here that same wining noise in the cabin at stop while on the brake.
Masscomguru
- Year and Model: 2010 XC90 V8
- Been thanked: 16 times
That sounds like your torque converter is failing... Maybe the rough idle is being caused by it not releasing fully? or clutches are grabbing?
humberto103
Aside from the above she drives and shifts good.
- 1949 Views
Last post by jakeempero
- 614 Views
Last post by pjmc480
- 18 Replies
- 1567 Views
Last post by bmdubya1198
- 2789 Views
Last post by DeadEric
- 17 Replies
- 1694 Views
Last post by vtl
