Buying a C70 with a broken timing belt?
paredown
Year and Model: 1999 V70
Been thanked: 2 times
Post by paredown »
cuhfs wrote:Just saw your post with the miles. 80K... sounds nice! if it has an automatic trans you will want to immediately do a fluid change and put a magnifine filter on it. The automatic transmission is a very weak link on these cars. both of my 04's had trans issues (96K miles, and 125K miles). Thankfully the 01 is a manual trans. But the 01's often have the dreaded faulty ETM... which I had to replace.
In the post about a C70 convertible for sale, I asked if there was a similar pre- and post- divide on the C70s like the P1 to P2 cars. Abscate pointed out that the forum puts them all together here, so clearly there wasn't a big change until the full facelift.
But I guess I was wondering if there were running changes that mirrored the changes with the P2s--so using the same transmissions and ETMs post-2000 that have showed faults in the V70s for example.
With our V70 (which had been treated badly--I mean black oil!), I did the sequential drain and fill almost immediately, and it definitely helped with a bit of stickiness in the shift points and smoothness generally and so far (@185,000--and about 26,000 miles by us) it has worked well. I just did the radiator, and looked at the fluid when I did the connectors on the rad, and it looks decent and smells OK...
I heard back from the seller--going to try to set something up for this weekend. I'm totally of two minds about doing it, but now my wife is on board (car would be for her) so I may end up getting it.
1999 na 2.4l V70 beater--donated to Habitat in running condition
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
I don't know the exact years of the AW55-50 problem transmission, and the years of the faulty ETM but the info is somewhere in the forum. You'll have to search for those exact years. Also don't know if there are any other faulty traits. I do believe that if that if the automatic top stops working that becomes a big problem with sensors and software that can be beyond the capability of DIY.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
