I have same exact issue on my xc90 t6.
Replaced sensor replaced bracket.
Initially had read about starter interference from worn brushes.
That solved the issue for about 2 weeks now back to hot start issue and reduced engine performance any time above 3k.
Maybe I'll check the bracket again....
V70 Crankshaft Position Sensor Problems
VTs70T5M
- Year and Model: 1998 s70 t5m
- Has thanked: 2 times
- Been thanked: 3 times
And hard start returned!! No jumpy tach no codes whatsoever.
About to make it an appt with a tree...
New starter, new cpk, new bracket, new battery, new coils, new plugs, added grounds cleaned grounds, shielded wiring moved wiring away starter/sensor harness.
Semi long cranks when cold excessive cranking to start hot...
Maybe it doesn't like this db electronics starter but was new not refurb and they have great reviews.
Turns fast has gpod fp at rail..
- Been thanked: 4064 times
What’s the measured fuel pressure at the rail?
- 5052 Views
Last post by regent
- 1275 Views
Last post by ducttapeandzipties
- 3508 Views
Last post by chrism
- 1363 Views
Last post by jimmy57
- 977 Views
Last post by jackief288
