Scotty Kilmer - Funny to Watch - AT205 Stop Leak
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Hi,
I was going to say try a little first too, but someone already alluded to this idea.
Maybe try using 1/4 of the recommended dosage first, then increase if needed.
Could save a lot of money i guess if it works.
Probably works on small leaks better than larger leaks.
If i thought of this when i had my old Hyundai when the engine seals started to go, i'd probably be driving that total piece of junk around still and still would not know that it was a piece of junk :-)
This is coming from someone who once used rock salt as an antifreeze at a time when i could not really afford to buy a gallon of antifreeze and the coming cold night crept up on me. Salt lowers the freezing point of water, but also acts to quickly eat up steel, so eventually it ate up the top radiator hose nipple and had to be replaced. As summer came the system was flushed and replaced with pure water for the time being. All that said and done, i got through the winter but had to buy a new nipple later some time.
Do i recommend this now? Not really unless it is going to be for a VERY short time period like one day so you can get through the night and get a gallon of the good stuff the very next day, then completely flush and replace with the good mix. I also wonder if anyone else has tried this nutty but effective idea. The alternative is a cracked block.
skloon
Year and Model: 94 850 95 850 04 S60
Been thanked: 2 times
Post by skloon »
I used it as the valve seals on my 95 10 valve 850 were leaking- stopped the smoke for about 8 months now it is back as bad or worse than before- if the seal is worn out there isn't much that anything can do, until we get some nanotechnology smart stuff that can seal only where it is supposed to and not other places it is merely a stopgap solution
rguzz
Year and Model: 1996 850 turbo
Been thanked: 25 times
Post by rguzz »
How much did you put in your crankcase?
cmblackburn
Year and Model: 1998 S70 T5M
Has thanked: 1 time
Been thanked: 7 times
Post by cmblackburn »
Scotty Kilmer is such a hack. Funny to watch him screw up everyone's car while shouting at you and using Autozone parts though!
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
cmblackburn
Has thanked: 1 time
He's such a hack. Funny to watch him screw up everyone's car with additives and Autozone parts while shouting, though!
PeteB
Year and Model: 1996 Volvo 850 Wagon
Has thanked: 57 times
Been thanked: 11 times
Post by PeteB »
I don't think he is a hack, he states outright that many of the cheap fixes might get
you a few more years out of a car.
BITOG thread on it: https://www.bobistheoilguy.com/forums/u ... er=2816155
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 13 times
Post by sleddriver »
OP: AT-205 is the real deal. Not at all like the junk "stop leaks" often encountered.
I personally used it to stop a BAD PS leak....no fluid added since. Just checked it yesterday.
Haven't added it to any motor oil though.
M1 10W-30 HM
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
I guess it worked on ny 96 R. I've had a?RMS leak ever since?I bought it and afzer gwtting it shipped thpugh amazon prime (i hate amazon, but I love my R) it seems to have slowed it down. Driving in the triple digits still causes a few drops on my garage floor, but it is better that spending a grand on a RMS job.
1996 855 R,
2010 V70 D5,
Clemens
Post by Clemens »
I guess it worked on my 96 R. I've had a RMS leak ever since I bought it and afzer gwtting it shipped thpugh amazon prime (i hate amazon, but I love my R) it seems to have slowed it down. Driving in the triple digits still causes a few drops on my garage floor, but it is better that spending a grand on a RMS job.
If you want to drive it to the ground it might serve your purpose, and if you want to keep it like I do you mifhz wanna redo all critical seals in the motor anyhow one day down the toad. Or road.
1996 855 R,
2010 V70 D5,
rguzz
Post by rguzz »
I doubt the stuff has any lubricating qualities so just use a tiny bit. If no untoward effects use a tiny bit more.
