Two steps forward, one back Topic is solved
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
Classic dried grease issue as stated above. Just did it. 96 year only problem I believe. Excellent write up above. Come to stop, turn wheel slightly to right, feel clunk in wheel on take off but if you use a little imagination it can be felt more in the steering column than anywhere else.
- Has thanked: 311 times
- Been thanked: 817 times
If you can confirm that the clunk is indeed the steering, then just get a new boot and new grease on that CV axle. I really would be surprised if it is bad.
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
My money is on one of the front strut towers binding/catching/clunking as the wheel is turned. Both struts rotate and are held in place from the upper strut bearings. Could be a needle bearing, something loose, something not fully seated upon reassembly, the lower strut mount bolts being tightened before the hub piece is firmly pushed inwards.Jaguar xjs wrote:Now on to the clunk. It seems the clunk can also be recreated with the wheel turned to the right. Mechanic found the right cv inner boot torn and the grease was everywhere as one would expect. Hard to believe I ran all the grease out of the joint in a week or so and trashed the joint.
All of this to say it might be a geometry problem: Something isn't properly lined up.
Jack the front end up off the ground, engine off, have someone turn the SW while you watch the strut towers from both sides and listen for noises.
M1 10W-30 HM
M1 10W-30 HM
Jaguar xjs
Erik called it right on. Did a wrench check this weekend and found the right sway bar loose on the bottom joint. However it wouldn't tighten. It appears the nut stripped on installation. Removed and replaced nut and all is well, no clunk.
Going to reboot cv next weekend if possible.
Gordon
Gordon
1996 850 turbo
1994 Jaguar XJS 4.0
1976 Triumph TR6
2012 Scion Xb
1994 Jaguar XJS 4.0
1976 Triumph TR6
2012 Scion Xb
- 650 Views
Last post by timetobakethedonuts
- 826 Views
Last post by rspi
- 1135 Views
Last post by Ozark Lee
- 2226 Views
Last post by E Showell
- 165 Views
Last post by Vova585
