850 no start issue. Cranks but won't start
Has thanked: 1610 times
Been thanked: 4071 times
The diagnostic path here should have been lack of 12 volts at injectors leading you to relay. Probably as weak battery inhibited ignition which clouded the picture here, ether should have given you fire if the fuel relay was sole problem.
