I actually like Hf/, but most corded tools that I've boughtbtherevhave failed on the fitrst or second use. I buy a lot of other stuff there though.erikv11 wrote:This is the more recent version of what I have: http://www.harborfreight.com/12-in-heav ... 68099.html
Whatever cheap impact you can find with those specs, or a more expensive one with better specs, it will do the trick. Especially given the salt-free roads where you live. Remember if the fastener gets stubborn it often helps to try tightening it. I know you don;t like HF and I can understand why, but you may pay a lot more for the same item at HD. I'd check Craigslist, too.
98 v70 axle nut stuck Topic is solved
98v70dad
- Year and Model: 98 V70
- Has thanked: 1 time
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
I use a Milwaukee 1/2 electric impact driver... It's never failed me. (Even after breaking two 1/2 breaker bars (one a Williams USA one!) trying to get out some Altima axle bolts this past December.) But the cheapest way to go about it would be to use a 3/4 and a breaker bar. No way you'd break something using that. Good luck.
Retired:
2015 Volvo S60, T5, 85K
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
Just adding my experience for what it's worth... As cuhfs recommends, I too bought the 3/4" drive 18" long breaker bar and the set of 3/4" drive sockets (which includes a 36mm) at Harbor Freight. I got a 5 foot long 1" galvanized steel pipe at Lowe's or Home Depot and put it over the 3/4" breaker bar. This set up worked great when I used it three years ago on the axle nuts.
It turns out I haven't used these tools for anything else yet, so it might be more economical to try an impact wrench, use heat, and/or get a shop to loosen the nuts.
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
In my case a professional auto shop could not loosen it and air nor electric impact wrenches would work. It was "check mate" - (out of options). And the original poster already has the pipe. Needs the 3/4 breaker and maybe can get a single 3/4 socket on ebay. I bought set from HF.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Been there. I was going to Sears every day.98v70dad wrote:Replacing my right side axle today and I can't get the axle nut loose. Everything else popped loose with no problem. I've bathed it in penetrant and so far I've broken a 1/2 inch drive ratchet and a 1/2 inch breaker bar at the 1/2 inch insert into the socket. I'm using a 4 ft pipe as a cheater.
I purchased a HF cordless impact gun and broke free a crank nut. Took about 10 minutes but it finally started turning. The shock of impact is priceless. I doubt the tool is still good enough to break another one loose, but hey, that one time was worth the $100 to me.
98v70dad
Thanks everyone. I bought the harbor freight electric impact wrench this morning and it broke the nut loose, although it took a few minutes. I had a 20% off coupon so it only cost me $40.00. I like HF tools if they work but my experience with corded tools is that the usually don't. The electric impact wrench worked for me, though. I've had a tough time finding a decent breaker bar to replace the one I broke, but I'll eventually find something that works well. I got my axle replaced. Volvo OE axle. Sweet but expensive. All I have left to do is torquing everything to spec. I'll do that tomorrow morning. I really don't want to use the impact wrench to torque the axle nut...we'll see what happens with the replacement breaker bar I bought.
98v70dad
If anyone can give me the torque values for the following I'd appreciate it. I'm sure I could find them here eventually but I've looked and they didn't pop up right away.
Axle nut.
Control arm at the frame
bolts for the RH side axle carriage bearing bracket.
Axle nut.
- gmh
- Year and Model: 2016 XC60 T5
- Has thanked: 28 times
- Been thanked: 22 times
From cn90's DIY: 1998 V70 Axle CV Rubber Boots Tips/Tricks
First post on page 2.
viewtopic.php?f=1&t=29716&start=10
Torque Values:
- Big 36-mm Axle Nut: 120 Nm then turn another 60 degrees.
- Control Arm Subframe Side: 65 Nm then another 120 degrees.
- (R) Axle Shaft Support 10-mm bolts: 25 Nm.
Torque Values:
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
1969 145S (1987-91)
1973 145E (1989-90)
- Has thanked: 311 times
- Been thanked: 817 times
Axle nut - really, really, really tight. OK I actually do usually torque this one, 120 Nm plus 60˚.
Control arm at the frame - really tight (be sure to pre-load!)
bolts for the RH side axle carriage bearing bracket - not very tight
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
Emphasis on pre-loading the control arms before tightening.
M1 10W-30 HM
M1 10W-30 HM
- 1080 Views
Last post by zombielinux
- 616 Views
Last post by Blacklab467
- 14949 Views
Last post by raymidd
- 465 Views
Last post by erikv11
- 754 Views
