How to reset Air Mass Flow (MAF) sensor adaptives? Topic is solved
Would a clogged PCV system cause the stalling once the pressure builds up?
'96 855 NA 269,000
'94 854 Turbo 162,000 rebuilding the head after a burned valve
'95 854 Turbo parts car
'03 V70 XC 142,000
'04 V70 NA 230,000
'04 S60 NA 152,000 oldest daughter's car
2005 Mazda 5, 5sd 163,000
2001 Excursion 7.3 power stroke 135,000
'03 V70 XC 142,000
'04 V70 NA 230,000
JRL
- Year and Model: Several
- Been thanked: 16 times
Possibly, especially if one of the vacuum lines is split
So yesterday I was finally finished with my '04 V70. I had in the end replaced the MAF( but that hadn't fixed the whining or the stalling), the PCV system (I believe that fixed the whining do to the diaphram being split), cleaned the throttle body( it was really dirty) and replaced all but the larger diameter vacuum hose that goes from the intake manifold to a tree under the upper part of the engine. Took it for a test drive and everything worked just like it should. Thanks to all who helped point me in the right direction.
'96 855 NA 269,000
'03 V70 XC 142,000
'04 V70 NA 230,000
'03 V70 XC 142,000
'04 V70 NA 230,000
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
You described something thats points to only one thing: the PCV box with crankcase pressure regulator valve is broken. The diaphragm on top of the box, used only on the non-turbo versions of your car, ruptures and puts crankcase in vacuum. The noise can be the valve "honking" or it s air coming in at shaft seals for cam or crank and making the kazoo noise. If you do glove test it will suck the glove down dipstick tube----DON'T DO IT!
- 2478 Views
- 9327 Views
Last post by jonesg
- 792 Views
Last post by landl4u2
- 956 Views
Last post by tamtam2122
- 1216 Views
Last post by jasontindal
