radiator damage 1998 V70 T5 Topic is solved
Has thanked: 1498 times
Been thanked: 3810 times
Re: radiator damage 1998 V70 T5
Correct. A compression test should be one hour of labor. Technically the car should be warmed up but that is a little. Hard to do without a radiator. You could put the two radiator hoses together with hose and fittings somehow and start it and run it until the temp swings up, then do the compression test.
A cold compression test will likely reveal any damage, though. It is possible you can have decent compression and still have head gasket damage but it's unlikely
101
Year and Model: 98 V70GLT, 98 S70T5M
Post by 101 »
enotslim wrote:You're saying the head gasket/compression can become damaged without any obvious, severe performance problems (for a short while), correct?
^^^ Correct.
Here's what I would do:
A compression test can be done without the radiator in place. Do that first. If that fails, then you know you at least have to remove the head.
If it passes the compression test, step two would be to have your guy look into the cylinders with a flex scope and see if there's any evidence of cylinder wall scoring. If the cylinder walls are scored, it's replacement engine time or scrap the car time.
If it passes both the compression test and the cylinder inspection, and you can have the radiator fitted and the ability to get a refund for the radiator if something shows itself afterwards, that's what I would probably do. Head gasket damage may be immediately evident or it may take a few cycles or miles to fully show itself.
Unfortunately, the odds are not on your side of having escaped at least a head gasket job.
Did the low coolant light come on while your son was driving it? That's my biggest fear - something lets loose and the indicator light doesn't come on for whatever reason.
101
1998 white V70 GLT 230K "Elsa"
1998 white S70 T5m 180K "Anna"
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Example 1: Our S70 ran fine for hundreds of miles at a time. Bad head gasket, exhaust gases getting into coolant chambers. Compression was perfect.
Example 2: The other day I went to see an 850 that lost all of it's coolant and they drove the car home. Replaced the rad, filled up the system, coolant was going into the oil and draining out of the back of the head.
These engines are very unforgiving of running out of coolant and overheating.
enotslim
Year and Model: 2004 XC70
Has thanked: 71 times
Been thanked: 16 times
Post by enotslim »
Can the engine be warmed with no coolant in the system in order to do a warm compression check? Or would a cold check be worthwhile in this situation? Or does it matter (very much)? Compression check before deciding whether to replace the radiator seems to make sense.
Dave
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
Just do it cold. Any massive lack of compression will be obvious.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
enotslim, if you haven't gathered from this threat, the thing is on our cars there isn't a head gasket compression (as an actual physical gasket)...the paint or roll on an anaerobic sealer between the head gasket and the upper engine... same sealer that is used on the cam cover.
enotslim
Post by enotslim »
Thanks for all the info and sorry for asking questions that were already answered. I somehow got out of synch with the thread.
Dave
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
Dave, focus on your car, don't worry about your netiquette, it's fine.
Hopefull the head survived the overheat and a rad will fix it up.
enotslim
Post by enotslim »
Parts correction. New rad is $359 plus ~$280 for new thermostat, hoses, clamps, o-rings etc. The latter would be slightly less OEM and less than half aftermarket (both from IPD) but probably not worthwhile given the overall cost. However, is replacing all hoses/clamps/thermostat reasonable if they seem fine? I know it's always safer to replace everything every time time but common sense says may not be necessary. Maybe the thermostat since I just had an overheating issue? Does overheating damage hoses?
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
I've got a 99 thermostat I'll donate if you want to save on this pass
Check part number to make sure it's the same
Nissens is fine, save money on the rad
