Before anyone starts tearing up the window motors,
it's worth keeping in mind that if the motor works
one way, but not the other, then the motor is OK.
99.9 times out of 100, the switches are the problem.
Can't get back window to roll up on my 1998 V70
- Been thanked: 4071 times
Can you do a quick test of switches by swapping connectors or are they keyed to the right one? I forgot from when I did my window switch replacement.
- Has thanked: 2207 times
I seem to recall you can swap them over from side to side on the master switch. Not sure about the rear door switches though.
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
remove the switch and clean it with contact cleaner or WD40, I had the same issue.
Then cycle it back and forth until it works.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- 12 Replies
- 3079 Views
Last post by BEJinFbk
- 8870 Views
Last post by jaseff
- 751 Views
Last post by motormikeyman
- 19 Replies
- 4592 Views
Last post by Ozark Lee
- 60 Replies
- 21983 Views
Last post by dana67
