Gauges dead. Matched the part numbers, tried three different clusters. All the same. Help?
Bamm
Year and Model: 2002 V70
Post by Bamm »
Strictly this issue. No other electrical gremlins have raised their heads yet. I apologize that I have thrown information around. Here's the clearest way I can give it to you.
All 2002 V70's.
Blue one, Green one, Silver one (parts donor), Black one (Parts donor).
Blue one - original dash works great. Green, Silver, Black dash clusters all fail.
Green one - Blue dash works great, all others fail.
Silver one - Silver dash works perfect. No others tested.
Black one - Black dash works fine. No others tested.
Bamm
Post by Bamm »
Thank you all again for the thought/time helping me with this.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
I've been told that besides the part numbers needing to match, the donor car and receiver car need to be the same year. Not sure if like years are compatible if the transferred DIM was ever "rebuilt".
What we do know is that Bamm's car and his wife's car are the same year. Also, his DIM fails in both his car and his wife's car. Conversely, his wife's DIM performs well in both her car and his car. This tells me both cars' CEMs are OK and Bamms DIM is faulty.
My guess is that the donor DIM won't work in Mrs. Bamms car either. Admittedly I kinda got lost with the car color part.
Has thanked: 1613 times
Been thanked: 4077 times
The CANBUS stuff can be tough to troubleshoot. Appreciate that trouble With any unit in the chain can pop a problem in the DIM.
IdahoBob
Year and Model: XC70 02, 04 & 08
Has thanked: 1 time
Been thanked: 4 times
Post by IdahoBob »
In case anyone else is reading this, thinking of swapping out a dead DIM, the "650T" on that label IS the critical number to look for on a replacement. If that number is different (600T on several '01's I've seen, 660T on the '02's I've seen), the replacement DIM will probably not work at all.
Idaho Bob
67, 71, 85, 98 wagons (sold)
78 coupe (gave to mechanic, thanks!)
02, 04 (X2) & 08 XC70's
before that: 67 Sunbeam, several pre-68 VW's, '41 Buick, '42 Ford Jeep, and some boring stuff
Bamm
Post by Bamm »
So, I went down to the local pick a part, found a 2002, $16 later installed the cluster in the parking lot. Everything works.......except the odometer and trip part. But at least I now know how fast I am going, engine temp and fuel level. Thanks for all the replies guys. Now to figure out the odometer/trip issue.
chrism
Post by chrism »
"...Everything works.......except the odometer and trip part..."
Any chance it's just a burned out bulb(s) in that part of the display?
Bamm
Post by Bamm »
Don't think so. Seems to be an issue related to swapping the dash clusters out. Sounding like I am going to have to bite the bullet and take it to a dealer to remedy that and turning off the air bag service light that came on after the swap as well.
