Lee, does a seal puller work on these axle seals? I have always wanted to get one...Ozark Lee wrote: 04 Jun 2017, 08:17 I just get a screwdriver behind it and pop it out. Be careful not to put a deep gouge the socket that the seal is installed in or it can cause a leak around the outside edge of the seal. Another technique is to drill a small hole in the edge and run a screw into it and then yank it out with pliers. You are space limited on the inboard seal and it is awkward to get to it which is frustrating since you can see it quite well.
