Ok - so I was never able to start the car with the MAF plugged in. It did however start and run OK (driveable) with the MAF unplugged, but was then obviously throwing a MAF code. I ended up getting a new MAF and as soon as i plugged it in, the car started right up and so far runs and drives like it should. I've driven about 50 miles, no check engine light so far.
The only weird thing is that I don't think I ever had a MAF code before the sensor stopped working. After it stopped working, it was too late to diagnose with the code scanner/computer as the code was being thrown because I had to have the MAF unplugged for the engine to run (which I found out more or less by trial and error...). I have a feeling it was the MAF all along, and the $ spent on the fuel system parts may have just been "collateral damage".
Anyway, Misha- thanks for your help.
New fuel pump and relay but still no fuel pressure!
nikolajs
- Year and Model: 98 V70 T5, 97 850 NA
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I'm still stuck on the car starting with no fuel pump relay???
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Me too,but it seems that it was overfueling and flooding the engine because of maf.
Fuel pump relay does not control just the pump...it controls a few sensors,which should be Maf and o2.
When he removed the relay...system had pressure in fuel rail enough to start and run engine for a few seconds...and removing relay acted just like he disconnected the maf.Main fuel injection relay controls injectors,coil.....so the car started and run with that relay disconnected untill there was fuel in fuel rail.
I hope that replacement Maf is oem Bosch 0 280 217 107.If not,you will have the same Maf problems pretty soon.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
precopster
- Year and Model: Lots
- Been thanked: 128 times
That doesn't explain how some folk can place a jumper in the fuel relay position and have a perfect running car for weeks. This post has just done my head in.
- misha
It explains everything IF relay itself is bad...and the thicker jumper wire is-it is better....for testing purpose,of course.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 2196 times
- Been thanked: 1850 times
There is another possibility worth checking on. I have seen a couple of times where there has been shorts happening under the fuse box where the fuel pump relay is fitted in front of the drivers side windshield wiper (not the kidney shaped main fuse box in the engine bay). The wires in those cases had crumbled and the insulation had fallen off and caused various shorts to occur. It may explain how the car ran without the fuel pump relay in place. Also, a less likely issue is to check there is no issue with the B+ cable in the main fuse box. Check the nut and the cable end are nice and shiny, but also look carefully under where the cable bolts down as mine had melted all the insulation in there!
- Been thanked: 504 times
The original post gave a lot of hint: "Unplug the MAF and the car ran better". Even without codes, that is a "give away".
Stick to Bosch MAF and you will be fine.
The fuel relay is a bit more tricky to diagnose: but a jumper wire (info in forum) is definitive diagnosis.
- 16093 Views
Last post by Richard99
- 20 Replies
- 13311 Views
Last post by oragex
- 11 Replies
- 2697 Views
- 5052 Views
Last post by wizechatmgr
- 5956 Views
Last post by chrism
