If you're near an auto supply store and you don't already have one, the inline spark tester would be a very useful purchase. You can visually check every plug wire using that tester.
One thing I discovered the hard way when I didn't have spark was that I turned over the engine with the spark coil high tension wire out of the distributor. That damaged the spark coil, so no spark.
Somebody on this site alerted me to that. How did that happen? I wanted to turn the engine over without ignition so it wouldn't fire up, because I was checking compression. So I pulled the high tension wire. Don't do that. Instead, disconnect the 12 v. input to the spark coil by disconnecting the plug with the wire release clip that supplies the coil. That won't damage the coil.
Not starting after head gasket replacement
- Has thanked: 311 times
- Been thanked: 817 times
Thanks, great tip!JimBee wrote: 19 May 2017, 10:38 ... disconnect the 12 v. input to the spark coil by disconnecting the plug with the wire release clip that supplies the coil. That won't damage the coil.
- 2603 Views
Last post by precopster
- 16 Replies
- 3447 Views
Last post by Craigd2599
- 26 Replies
- 3943 Views
Last post by tardcart
- 101 Views
Last post by dikidera
- 1190 Views
Last post by beewstew
