97 855 GLT EEC Trouble code help Topic is solved
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 334 times
Re: 97 855 GLT EEC Trouble code help
Post by Chuck W »
AKJeeper wrote: 09 Jun 2017, 12:11
I'm going to make another one on how to get the system to relearn the damper motor positions at some point in the near future...
That would be a useful one.
Chuck W
Post by Chuck W »
abscate wrote: 08 Jun 2017, 15:07 Software, high end scanner, or Volvo Dealer - it won't reset with a battery disconnect
I've got a video on how to read and clear the codes with a home made tool.
Do you happen to have this info handy? Even if not on a video yet?
Chuck W
Post by Chuck W »
I cleaned out the fans on the interior temp sensors and reset the codes.
Was left with 2-3-1 - Ventilation Dmpr Motr Position Sensor Circuit Open or shorted to power.
Chuck W
Post by Chuck W »
OK, well today's 4 hour odyssey involved trying to fix this nonsense.
The first thing was to clean out the sensor fans.
After that and the DTC from above (2-3-1) I just went ahead and pulled out both temp damper motors, the ventilation damper motor and the floor defrost damper motor. Cleaned off the position tracks (all had some grease on them) and reinstalled them.
After that, I wanted to to do the 9-9-9 damper motor position relearn thing. Looking at the manual, I figured out how to perform it, but I can't get it to take.
Self-Adjustment Of Damper Motor Limit Positions
1) Turn ignition on. Place fan (blower motor) lever in manual mode. Turn function selector to AUT (automatic). Ensure system is in TEST MODE 4.
2) Enter control code 9-9-9 by pressing button on diagnostic unit 9 times in quick succession. Enter each of the 9 series 3 times, with a short pause in-between to allow LED to come on again. ECC control module is now ready to adjust damper motor limit positions automatically.
3) Wait about 10 seconds for fan to start. Turn ignition off to exit TEST MODE 4. Turn ignition on. AC OFF and REC indicator on A/C control panel should flash. Drive car for a few minutes at speeds greater than 20 MPH.
4) Stop car and turn engine off, but leave ignition on for at least 2 minutes to enable ECC control module to store all values.
Start TEST MODE 1 and record DTCs. If DTC 1-1-1 appears, selfadjustment is complete. If DTC 5-1-1 appears, self-adjustment is not complete.
I did it twice, but still get the 5-1-1 DTC. The first time I shut the ignition off instead of leaving it on. It's kind of hard to turn engine off and leave the ignition on (In POS II). So maybe that's my issue.
After checking and erasing codes a couple times, I've wound up with these DTCs.
2-3-3 - Floor/Defrost Damper Motor Position Sensor Circuit Open Or Short To Power
3-2-4 - Floor/Defrost Damper Motor Active Too Long
5-1-1 - Self-Adjustment Of Damper Motor Limit Positions Not Carried Out
Right now that damper is in full floor mode, and won't switch to defrost. I've had it apart and cleaned it and tested its operation with a 9V battery, so it's not stuck.
Chuck W
Post by Chuck W »
So, we're going to try and score another damper motor at the PnP this weekend.
A bad damper could also be what's keeping the system from self-adjusting the damper limits, I assume?
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
I had good luck with two of my original dampers -- cleaning the carbon tracks restored normal operation. I tried cleaning the third one but it wouldn't work correctly. I had to replace it with a spare, which has been working fine for a couple years so far.
Chuck W
Post by Chuck W »
jreed wrote: 15 Jun 2017, 05:12 I had good luck with two of my original dampers -- cleaning the carbon tracks restored normal operation. I tried cleaning the third one but it wouldn't work correctly. I had to replace it with a spare, which has been working fine for a couple years so far.
This one has been apart and cleaned a couple times, so I think it's toast. All of the ones I took apart were pretty covered in grease. There are 2 850's in the yard right by us, so we should be able to score a couple extras to keep on hand.
Chuck W
Post by Chuck W »
So, had a chance to spend more time on this over the weekend. Grabbed a couple spare damper motors from an 850 at the PnP down the road.
Pulled the Floor/Def motor out and installed a "new" cleaned, tested one.
After that, I tried to self-adjust the motor positions with the "9-9-9". Took it for a drive, as instructed.
Came back and STILL get the "5-1-1" code, indicating that the self-adjustment didn't work.
Additionally, the old DTCs were gone and now I'm stuck with a "3-2-3" which is "Ventilation Damper Motor Active Too Long". I grabbed the spare I pulled from the yard and cleaned the position tracks. Then wrestled it into place, trying to keep the two gears lined up properly. Royal pain in the butt, really.
Pull it all back together and STILL have the "3-2-3" and "5-1-1" codes. Even after a couple attempts of erasing codes and self-aligning...
What am I missing here?
Chuck W
Post by Chuck W »
Thinking about something with the Vent Damper Motor.
Should the big internal gear be more in the middle of its adjustment range when trying to get it aligned and installed with the gear on the flapper? There is the larger tab/slot in each of the two gears, which is probably the alignment index. They weren't engaged when I removed the first one (previous owner had been there, evidently) and there are no references in the manual about the alignment.
jreed
Post by jreed »
I'm not sure about the Ventilation Damper. For the driver's side damper motor, the gear angle was about at the middle of it's range. Photo here:
viewtopic.php?t=50525
