2002 V70 XC Turbo-replaced PCV system-now won't start Topic is solved
- Been thanked: 4064 times
That might have been it. I certainly had a lot of air in the rail after removal. I don't remember a bled step in VIDA bu t that makes sense
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
I never looked up the procedure in vida... KPII (don't start) pressurizes the system air and all, use the schraeder valve on the fuel rail to purge the air. It only runs the pump for a couple seconds with the engine not running so you have to repeat as necessary till you get just fuel/no air bubbles. Trying to start the engine dry of fuel isn't good for the injectors.abscate wrote: 26 Jul 2017, 20:33 That might have been it. I certainly had a lot of air in the rail after removal. I don't remember a bled step in VIDA bu t that makes sense
aaron1611
- Year and Model: 2006 XC90 V8
- Has thanked: 2 times
- Been thanked: 5 times
ok, here's the latest. Replaced the oil and filter and the car runs great but when I first started it up and took it for a drive I did get the error message again, reduced engine performance but within 10 mins. it went away and didn't come back on during my test drive. Then again this morning it came on but went out after 10-15 mins. I will continue to monitor it and will do another oil & filter change in a couple hundred miles. I'm also going to do the transmission flush as seen on this forum as I can feel the transmission is not shifting smoothly. I've got the siren module on it's way which I'm hopeful will again allow the sunroof to work. Turbo seems to run excellent. So, unless that error keeps coming back I consider this thread solved but will post back if it does continue to happen.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
91 240 Wagon 5 speed 211K daughters daily driver sold
2013 XC90 wife's daily driver 201K
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
Volvo's that were driven and flipped:
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
Thanks for keeping us up to date Aaron , feel free to add to the thread, they never die!
precopster
- Year and Model: Lots
- Been thanked: 128 times
Siren module let's sunroof work? Hmm.
The circuit board contained in the rear vision mirror called UEM has the sunroof function. Have you tried using the remote at least 3 times in a row (unlock/lock) to kick the board back into operation??
aaron1611
Well, it seems the problem persists even after warming up and driving for 30 mins. It's not duplicatable in that I can press hard an accelerate nicely at times and at other times I get the error or I can be coasting or cruising and get the error. at 20 mph or at 80mph. It's a Bosch ETM that looked in pretty good shape with not much build up when I cleaned it but could this still need replacing? I don't have any CEL's and when I scroll through the DTC's, holding info button & hitting rear fog light button twice to activate it on the info screen on dash everything checks out ok.
No go on the sunroof. I once in awhile get the "alarm system needs servicing" saying or close to that and I dug deep on another forum that mentioned replacing the siren module will restore a non-working sunroof. If not, no big deal.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
DanelleNavarro
- Year and Model: 2002 v70xc
Hey everyone... I just wanted to share what I did to the PCV hoses on Harry the Volvo... I'm waiting for a new PCV system but in the meantime I still need to use my car. So today I went to Harbor Freight and bought some shrink tubing and the salvage yard for a set of hoses better than mine. I replaced the old with the new ish and wrapped them with the shrink tubing. Harry the Volvo is very happy.
- 620 Views
Last post by 2002VolvoC70
- 1146 Views
Last post by MadeInJapan
- 1446 Views
Last post by ricebw2
- 12 Replies
- 2417 Views
- 1955 Views
Last post by MVM17
