Fuel injector, broken "washer" on manifold end?
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 9 times
Been thanked: 22 times
Post by prwood »
vtl wrote: 30 Jul 2017, 16:07 Search on ebay "Volvo 98-05 fuel injector kit", like $15 for 6 injectors.
Thanks, I checked it out, looks like the right fit.
Just out of curiosity, on a scale from 1 to 10 where 1 is slight decrease in performance or fuel economy and 10 is permanent engine failure, how bad is a broken pintle cap, if the injector was installed in that state? What about a missing one?
Cars I've owned:
- 2015 to current: 2001 Volvo V70 2.4T; 2004 Honda Odyssey
- 2007 to 2015: 2002 Subaru Legacy L Wagon
- 2003 to 2016: 2001 Toyota Corolla LE
- 1999 to 2003: 1994 Toyota Camry LE
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
prwood wrote: 30 Jul 2017, 20:58 Just out of curiosity, on a scale from 1 to 10 where 1 is slight decrease in performance or fuel economy and 10 is permanent engine failure, how bad is a broken pintle cap, if the injector was installed in that state? What about a missing one?
0 on that scale.
prwood
Post by prwood »
vtl wrote: 31 Jul 2017, 00:32
0 on that scale.
Thanks. So I'm probably best off just leaving everything as is (other than replacing the O-rings).
FWIW, I had also emailed iPd asking about this, and this was their response:
iPd wrote:...that piece is not something that is available separately. The good news is that you really don't need it. it is very commonly broken anyway.
So, based on everyone's responses, it sounds like something I don't need to be concerned about.
Cars I've owned:
vtl
Post by vtl »
prwood wrote: 31 Jul 2017, 11:01 So, based on everyone's responses, it sounds like something I don't need to be concerned about.
Sounds totally unacceptable for a perfectionist ;)
I pulled fuel rail twice to fix that (and to clean/rebuild injectors while was there).
prwood
Post by prwood »
vtl wrote: 31 Jul 2017, 11:05
I sometimes exhibit perfectionist tendencies, but at this point that has given way to "I just want to start driving my freakin' car again, ASAP."
Cars I've owned:
Has thanked: 1610 times
Been thanked: 4068 times
prwood wrote: 31 Jul 2017, 11:09
Dont worry, we will beat that out of you here. We even convinced one guy he can re-use his old engine oil...
There is a slight chance I will cruise by your way this week and can throw a coil your way if eBay is slow.
brettbo
Year and Model: 1999 S70
Post by brettbo »
I just broke all of mine putting my fuel rail back in. Loosened the manifold to vacuum the pieces out. I assume these all just melt off anyways but would prefer to not have that crap laying around in there. Just bought 2 replacement kits on eBay. Par for the course on all that's happened to me on this pcv system replacement.
EngineeringBloke
Year and Model: 2006 2.5T S60
Has thanked: 57 times
Been thanked: 39 times
Post by EngineeringBloke »
So about 'pintle caps'. On some injectors, there is a pin that projects out of the end of the injector (manifold side). There is a plastic piece shaped like a top hat (with a hole in the middle for the pintle pin to project through). That is appropriately called a pintle cap. On our Bosch injectors, the solenoid and any related pin is totally recessed and so does not need a pintle cap. Instead we just have a retaining washer that holds back the o-ring. But on the other hand, what are we going to call it.
On doing my injector o-ring renovation recently, the middle injector came out without the manifold side o-ring. I got that out from the manifold and saw the o-ring washer in two halves resting in the injector hole of the manifold. Using extreme care and caution, I removed the first half, before pushing the other half into the manifold. I tried to blow it out of the hole using strong words. After that, I took out the spark plug and tried to blow it out with canned air, unsuccessfully. I even pulled the fuel pump fuse and spun the engine (rag over the fuel line), but the half plastic washer is gone (for now).
I got a set of micro filters to go in the fuel rail end of the injectors with my o-ring kit, so I tried to remove one of the filters but the tool I used did not work. As this operation damaged the prior filter and I had concerns about what might have got past the filter and into the injector solenoid, I bought a replacement injector and put that in.
All in all, the car remained usable and did not burn down, but I was disappointed with my work. I am inclined to just buy 4 more injectors so that I can be assured that they are all equally new (more or less) and equally clean. At least I gained experience working on a new subsystem of the car.
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
A few MVS members including myself used this fuel injector kit with good success
https://www.aliexpress.com/item/Free-sh ... 58425.html
This kit contains a tool to remove the filters.
The caps in this kit are also a closer match to OEM than the kits on Ebay and Amazon.
EngineeringBloke
The Ebay caps I used were slightly cone shaped, instead of flat but fitted well on the injector, held the o-ring and were still in place when I removed the fuel rail a couple of days after the install to switch out one injector with the bad filter.
However, if I had the aliexpress kit, I probably could have removed the microfilter with the kits filter extraction tool and not needed to buy a new injector!
