Your 2002 will have variable valve timing which means the cam sprocket moves relative to the cam. You have a few more steps to put this back together compared to a fixed cam car.
We have some threads on this and also stuff in the VRD
YIKES!! 15 Qts. of oil to get home tonight Topic is solved
- Has thanked: 1613 times
- Been thanked: 4077 times
aaron1611
- Year and Model: 2006 XC90 V8
- Has thanked: 2 times
- Been thanked: 5 times
it got dark and I'm heading out of town for work but I almost have it together. Need to install the timing belt etc. but the hard work is done. I'll post back next weekend when I'm back in town and have time to work on it.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
91 240 Wagon 5 speed 211K daughters daily driver sold
2013 XC90 wife's daily driver 201K
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
Volvo's that were driven and flipped:
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
Research preloading the sprockets for when you reinstall the belt, that's important. If you just line up the marks I don't think it will interfere, but it will throw a cam code.
I'm not positive forgetting the preload is safe, so don't risk it.
aaron1611
hmm, I can do that. I did end up ordering cam tool to keep them in place since I've got VVT and I'm sure that getting the belt around them will most likely want to make them move despite my "homemade" setup. I miss the good old days though.... my first car was a 60 bug and it was such an easy vehicle to work on. So were my Mopar vehicles, 383's & 318's.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
That thing you could swap an engine with a screwdriver and a pliers. Good old daysaaron1611 wrote: 21 Sep 2017, 15:14 hmm, I can do that. I did end up ordering cam tool to keep them in place since I've got VVT and I'm sure that getting the belt around them will most likely want to make them move despite my "homemade" setup. I miss the good old days though.... my first car was a 60 bug and it was such an easy vehicle to work on.
Yeah, but bottom ends last 100k , and valves/heads even less...vs 300k for P80s
I love my Beetle, but it's no Volvo...
I. Forgot to issue the Swedish horns to Juniorette for shutting the engine off after the oil warning and saving the engine...well done!!
aaron1611
yes, good old days and double yes to my 11 yr old for noticing the light and taking action!! I'm back at it now and I opened up my kit that I ordered and it doesn't have any instructions I see how to use it if you remove both cam sprockets but I will tool around on the web but I'm a bit concerned that I wasn't fully aware of how to set up your sprockets prior to removing the timing belt. I turned clockwise to align the two cam marks to my plastic belt cover and confirmed that my crank was lined up below and I actually went counter clock wise to align as perfect as I could, but just a 1/8" or so. Now, my homemade cam lock slipped a bit and the left cam (VVt cam) moved a few teeth by mistake but I moved it back to alignment with the cover. before I put it all back together please confirm that as long as bottom is TDC and the two cams line up, am I good to reassemble? Once together, rotate timing belt a few revolutions by hand to confirm that my marks line up? Thanks,
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
aaron1611
i will say that my vida and it's directions/repair notes at times differ from what I'm reading on these forums as well as even my components don't always align with diagrams seen on vida or forums.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
Stop.
Do not pass go.
Do not turn that engine over.
The VVT heads must be preloaded, you can't time them by lining up the marks statically like 1998 and earlier
Do not pass go.
aaron1611
well, I put it all back together and it fired right up and runs great.......except the leak slowly came back. I soaked the entire area with a can of brake clean and then using my compressor blew everything clean and dry and started it back up and it's looking like my intake cam seal is leaking, not the exhaust vvt on my left but the forward cam. Really bummed but it's part of owning these volvo's.
All that being said, I am now seeing abscate's post about preloading my vvt exhaust cam. I guess just because all my timing marks line up and it idles nicely it's Not actually fixed?
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
- 13652 Views
Last post by oragex
- 37 Replies
- 10494 Views
- 976 Views
Last post by precopster
- 1124 Views
- 3125 Views
Last post by cn90
