Weak Brakes on 95 T-5r
warmblood58
Year and Model: 1989 245
Has thanked: 5 times
Been thanked: 2 times
Post by warmblood58 »
tech bleed brakes per Volvo procedure -they definitely feel better but I was hopping to be able to lock them up -does ABS prevent this? Rear rotors are blue'd- past sticking calipers? Most likely I will install new rotors next after ensuring that there are no sticking/heat issues lingering - I use a temp thermal gun for this, definitely a handy tool to have.
Has thanked: 2202 times
Been thanked: 1852 times
Blued rotors will reduce the braking efficiency significantly. Time for a new/good used caliper and rotors.
warmblood58
Thanks Neil!
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
When you open the celiper bleeder and pump the brakes, does the fluid flow a lot or just a bit out of the bleeder?
Try opening the bleeder, turn the ignition key to Pos II then pump the brake pedal fast and strong - place a 2" piece of wood under the pedal so it doesn't go to the floor. Repeat at all 4 calipers.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
warmblood58 wrote: 27 Sep 2017, 12:20 I was hopping to be able to lock them up -does ABS prevent this?
Anti-Locking Brake System prevent wheel lock under braking.
85 GLH, 367 whp
00 Insight, 72 mpg
As tryingbe says, you won't normally feel the ABS working on regular driving. You only feel the ABS kicking in if the wheels are slipping like on gravel. Try driving on a gravel road or long drive and hit the brakes. If you get the pulsing from the brake pedal and the accompanying noises then your system is working.
