A seafoam use that makes no sense but worked
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Just for the sake of clarity, the proper seafoam to use is the intake cleaner right? Not the fuel additive stuff.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
I usually use the liquid in the can not the spray.
Dump half in the fuel, half in the crankcase. If you're really looking for improvements with blowby, take another can and remove all 5 spark plugs and pour it in to each cylinder in even proportions. Let it sit for several hours, then turn the crank by hand. Let it sit for a while longer. Then crank it over a couple times with the starter. Replace plugs and fire it up. You will have a white smoke event - it will clear...
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
It works. It is not a miracle tool, but it works. It can solve oil consumption if the oil rings are stuck, recover engine compression if the piston rings are slightly stuck. On my engine it corrected the engine pressure: at idle I was having a slightly positive crank pressure because of stuck piston compression rings. After the treatment (described below) I have good vacuum pressure (all PCV system being in good condition).
There are a few important tips.
These engines don't have the pistons perfectly vertical. On my P2 the engine is tilt about 10% towards the rear. Because of this, the top of the piston - and thus the rings - don't sit horizontal. For the treatment to work all around the ring(s), the car must be parked with the front diving on a about 10% incline - or just enough to have the top of the engine horizontal.
It is much better to do the treatment on a cold engine, and even better in a cold winter day. The pistons are in alloy and will shrink more so than the steel rings (except for the oil ring). This will increase a little the gap between the piston and the ring allowing the Sea Foam to penetrate into the ring grove better.
I would pour about 1/2 oz into each cylinder and leave it for 1-2 days, then turn the engine at the crank 1 turn and repeat.
The Sea Foam should slowly leak into both compression rings grooves down to the oil ring groove.
Change the oil and filter - better done just before an oil change.
PS Don't use any other fluid for this task, they risk damaging seals inside the engine.
- 37 Replies
- 6777 Views
Last post by RickHaleParker
- 865 Views
- 945 Views
Last post by Craigd2599
- 1816 Views
Last post by rspi
- 807 Views
Last post by Clemens
