power steering fluid question for 2011 XC90 3.2 I6
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
You may want to change all fluids one at a time. PS is a good start https://www.ipdusa.com/products/5743/11 ... ring-fluid
- SuperHerman
- Been thanked: 207 times
CHF 202 is compatible with CHF 11S and the same color. They can be mixed together without issues. CHF 202 is easier to find and from what Pentosin states it is Volvo approved from 2002 on.
http://www.pentosin.net/pressreleases/C ... _Guide.pdf
Note in the brochure the last line stating: "CHF 11S and CHF 202 are fully compatible and mixable. Pentosin CHF fluids should not be mixed with ATF fluids."
It isn't worth the hassles to change to ATF, as either of these two fluids for minimal additional costs will keep you on the same path moving forward which makes maintenance easier long term.
- 30 Replies
- 27580 Views
- 6204 Views
Last post by EngineeringBloke
- 2232 Views
Last post by MoVolvos
- 1531 Views
Last post by Krons
- 13 Replies
- 3349 Views
Last post by ggleavitt
