Before tearing into that engine, I suggest performing a combustion gas test to verify that is the problem. It is easy to do and you can borrow the tool, just have to buy the liquid. Junethienle wrote: 22 Sep 2018, 08:23 If that the case then I might have a blown head gasket. The top of the pistons are not uniformly dirty. Some area is cleaner than others. I took a few photos of the top of the piston but don't know how to attached to the post. Any instruction on how to replace the head gasket or a diagram of the "explore view" of the engine is greatly appreciate.
Cooling system pressurized
- June
- Has thanked: 523 times
- Been thanked: 261 times
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
thienle
- Year and Model: S80 2001 nonturbo
I rented the chemical test kit from Autozone and performed several tests from the overflow tank. All tests came back negative with no indication of a blown head gasket (assuming that I done correctly). I also checked inside the oil cap, it too, appeared to be normal. I've replaced the thermostat. I just found out that there is a small leaks at the upper radiator hose to the engine on the radiator end. I removed the upper radiator hose on the radiator end and found out the connector from the radiator was damaged. The rubber coated on the connector on the radiator was brittle and falling apart causing a bad seal. Found a cheap new radiator on ebay but it only compatible to the "2917CC" but not to "2922CC 178Cu" engines. I wasn't aware that 2.9L Volvo has two type of engines? Please advise how can I find out what type of engine is in my vehicle so I can purchase the correct radiator. Below are the two engines listed on the ebay. Thank you very much.
2.9L 2917CC I6 Gas DOHC Naturally Aspirated
2.9L 2922CC 178Cu In. I6 Gas DOHC Naturally Aspirated
Ebay link: https://www.ebay.com/itm/Radiator-Volvo ... 0935.m2460
- SuperHerman
- Been thanked: 207 times
The engine will be listed on the sticker that is on the hood or in the engine compartment maybe radiator support. It will tell you which engine you have. You can also use your vin and go to tascaparts.com and enter the information and click until you find the radiator and the applicable part number. This is the best approach.
I feel bad I didn't mention trying a pressure test as that would have found your issue pretty quickly.
