PCV hose and EZ-Coils
- Has thanked: 311 times
- Been thanked: 817 times
That's a larger diameter vacuum line than I have, maybe that's contributing.
BlackBrick
- Year and Model: 1997 850R
- Been thanked: 3 times
yeah, i heard some say drill out the PTC, and some say go with a larger diameter vacuum hose. Maybe we should only do one or the other? Will reply after this weekend with my result.
These Volvo PCV systems sure keep us busy!!!
BlackBrick
Ok, replaced the PTC, idle issue and code is gone. I had drilled out the bottom of the PTC AND the vacuum hook up. That must have created too much vacuum. Now I just drilled out the bottom of the PTC.
By vacuum hookup you mean where the 1/4 fuel line connects, right? And are you still using 1/4 line, thanks.
BlackBrick
Yes. The 1/4" fuel line for vacuum from passenger side of manifold to ptc. Inside the plastic hookup (actually 3/8") you can see a pinhole. I did not drill it out this time.
BlackBrick
1 month follow up. Since replacing my clogged pcv system with 5/8" fuel hose, I've gone from burning one quart of oil per month down to 1/4 quart per month. 1997 850 GLT with 195,000 miles. Quite happy with that.
- 2990 Views
Last post by greg850r
- 407 Views
Last post by Vova585
- 5976 Views
Last post by chrism
- 1307 Views
Last post by mrbrian200
- 1029 Views
Last post by Roger_850T
