Immobilizer, see manual. Break failure, stop safely. Low beam failure. Light on antina ring not turning on.
Damianmcc
Year and Model: 07 XC90
Re: Immobilizer, see manual. Break failure, stop safely. Low beam failure. Light on antina ring not turning on.
Post by Damianmcc »
Does not turn over at all.
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 23 times
Been thanked: 125 times
Post by ggleavitt »
Thanks, the immobilizer message was reported but wanted to confirm the scenario. Original battery in this car? OE from around this time should have a date-code stamp on one of the terminals.
Car thinks there more than just the immobilizer at fault based on your original post, sometimes an old battery will cause modules to act out. Anything out of the ordinary before things started going bad, anything at all that you can think of?
As others have mentioned, getting a Volvo centric code reader on this car will point you pretty quickly in the right direction.
Thanks again for the clarification.
2006 V8 Ocean Race #740/800 200k, 2008 V8 Sport 183k
