2005 XC70 engine just got a whole lot louder
- Been thanked: 4069 times
If you go stainless on the bolts/nuts, they are a lot easier to grind off when seized....much softer. Plenty strong enough for the application. I use junk SS from Lowes for this.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Junk chinese SS is not bad at grinding indeed. On the other side, real SS is in theory quite harder than regular steelabscate wrote: 01 Nov 2018, 09:26 If you go stainless on the bolts/nuts, they are a lot easier to grind off when seized....much softer. Plenty strong enough for the application. I use junk SS from Lowes for this.
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
You don't want stainless. You want the bolts to rust instead of the exhaust.
The same applies for that little bolt on the inside of every door that's always rusted.
Ive gotten so used to grinding cheap stainless I had forgotten this, and you are absolutely right.oragex wrote: 01 Nov 2018, 09:29Junk chinese SS is not bad at grinding indeed. On the other side, real SS is in theory quite harder than regular steelabscate wrote: 01 Nov 2018, 09:26 If you go stainless on the bolts/nuts, they are a lot easier to grind off when seized....much softer. Plenty strong enough for the application. I use junk SS from Lowes for this.
- 203 Replies
- 10715 Views
Last post by volvolugnut
- 4089 Views
Last post by FLXC90
- 7685 Views
Last post by buffmont
- 558 Views
- 2237 Views
Last post by SuperHerman
