LTF takes a looooong time to change, and I drove for quite some time with a bad O2 sensor w/o codes and intermittent sputtering/black smoke. Reset would take care of it for a week or two. You're right that air leak isn't probably, since an ECU reset wouldn't fix that, and the MAF would be short term fuel trim troubles, mostly. The combo of a bad MAF and bad O2 could definitely result in your issues, with the work you've done, the ETM is probably a better bet.dobrosailor wrote: 03 Dec 2018, 04:31 So, between incidents, the car runs absolutely great, not running rich, no computer codes just happy Volvoing. I have a friend with a Volvo Junk yard so I have about 4 MAFs I've tried, it idles great so I doubt there is a air leak and there are no O2 sensor codes...
- S
