1996 850 Base NA Severe Misfire after smooth running
zupta82
- Year and Model: 1995 960
Sorry, by the way I did check under the distributor cap for oil and moisture, and it is bone dry. I’m thinking this has to be a main 12v battery problem or ground problem. The first time I checked for these I had continuity from the negative battery cable to back both ground straps and no resistance on my meter so I’m guessing it can’t be a short. I also checked for continuity at the positive battery cable all the way to the thick B+ cable at the alternator . Keep in mind I had the battery totally disconnected and removed fro the car when doing this
- Been thanked: 4068 times
Better way to check the cable.
Install the battery. Turn on electrical loads like headlights And fan on high.
Measure voltage across battery, record
Measure voltage from starter lug and negative post. Be careful with that test probe as if it touches metal it will melt.
Record second voltage. They should be within 0.1 V
Method 2..even more exhaustive..repeat measurements while cranking
Method 3 start car , put on lots of electrical loads like full headlights, fan. Measure temperature of positive cable over 5 minutes with IR sensor
zupta82
I checked the the battery exactly like abscate said. I also checked the voltage during cranking and it was about 0.840v for a second then it settled to 14 volts, so i’m guessing the charging system is working and the battery cable is at about 52 degrees after 5 minutes and was not warm to the touch. I replaced the timing belt with a new full kit tensioner,water pump,pulley,etc 4 months ago. I did notice that the car wasn’t as peppy as my father 850 of the same mileage. I was thinking of testing for the catalytic convertor with the use of a vacuum gauge can someone please tell me how to proceed with this
tardcart
- Year and Model: 96 850t. 93 940t
- Has thanked: 3 times
- Been thanked: 37 times
If its caused by rich fuel mix (wet plugs) check fuel isn't being sucked in from the fuel pressure damper vacuum line. I think the NA's are famous for this.I dont think its the exhaust. It would run smooth and quiet at idle. also some more information on circumstance preceding problem helps such as I filled the tank with an old tank of gas that may have water in the bottom and three days later...
- Has thanked: 311 times
- Been thanked: 817 times
As tardcart suggested, actually check the timing. Get the front end in the air, put the crank on the mark and see where the cam sprocket marks line up. Bit of a hassle to test but it's free!zupta82 wrote: 02 Mar 2019, 13:38 ... I replaced the timing belt with a new full kit tensioner,water pump,pulley,etc 4 months ago. I did notice that the car wasn’t as peppy as my father 850 of the same mileage. ...
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Depends on how far it jumped. You'd know if they hit...
- 73 Replies
- 30312 Views
Last post by quietcoolone
- 887 Views
Last post by kahl
- 2363 Views
Last post by SuperHerman
- 1904 Views
Last post by RickHaleParker
- 1152 Views
