Get a loupe ( that’s optics , not a disease or a wolf) and have a closeup look at the big pins. Look for cracking in the solder around the pins.
Don’t overthink the cause too much, it’s a 17 year old car and it is inventing new failure mechanisms yet to be uncovered by us here.
"Brake Failure" P0571 and P0504 Topic is solved
- Has thanked: 1611 times
- Been thanked: 4075 times
Marcobrick
- Year and Model: 2003 V70T5
- Has thanked: 3 times
Funny you should say that. There is no solder in evidence around any of the pins!abscate wrote: 15 Mar 2019, 06:03 Get a loupe ( that’s optics , not a disease or a wolf) and have a closeup look at the big pins. Look for cracking in the solder around the pins.
I flowed solder around all the pins on the board last night. Problem persists! I’ll get the codes read at the dealers next week. Meantime I’m pricing up a new BCM. ($OUCH$)
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
1973 Land Rover Series 3 flat deck.
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1995 850 Turbo Wagon
1998 V70T5
Favourite line: "How hard can it be?"
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Might the mechanic have accidentally introduced air into the system? Or might he have pushed the pedal to the floor repeatedly and possibly damaged the piston seal?Marcobrick wrote: 14 Mar 2019, 21:58 The brake failure message appeared while driving home after having the brakes bled by his local mechanic.
Marcobrick
I doubt the seal is compromised . There would be something physically wrong with the brakes then, but apart from no ABS they work perfectly.chrism wrote: 15 Mar 2019, 12:05
Air is the abs pump maybe but I don’t know if the computer could know that?
The ABS module (BCM) is under heavy suspicion if for no other reason than it’s been hacked open by a previous owner. Still need the codes read by VIDA.
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
Marcobrick
Ok, so this afternoon I got an “engine system service required” message. I plugged in my code reader and I had the P0571 and P0504 twice each... I can’t erase the first set but I can erase the second set. This left me with fully functioning ABS, trip computer and odometer!! For about 1 mile. Then the whole lot came back. I went into the auto parts store for some oil and when I restarted the car, all clear again. Another mile down the road, Christmas tree lights on the dash..you get the picture.
I think my soldering has done something, but since I suck at soldering I just haven’t got enough penetration. In truth I’m too scared to apply a lot of heat to a circuit board because it’s the first circuit board I’ve ever touched.
I might crack it open again, suck out my crap solder and have a do-over. I have a friend who’s into electronics, I’ll ask him for some guidance and maybe some better equipment.
Feeling like I’m confident its the abs module now!
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
Marcobrick
When I parked yesterday, there were no faults. This morning the warnings were there as soon as I turned the key. I removed the BCM and took it to my friend’s house. He tested all the circuits fron the connector pins and could find no faults. The BCM is now in the freezer to be tested later when cold.
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
Marcobrick
FAIL. Making it cold didn’t replicate any faults. My friend undid my handiwork and resoldered the pins nicely but now my problem is again permanent.
I did achieve one positive thing today, the engine compartment fuse box was not mounted correctly. It is now!
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
chrism
Is this the part you replaced?Marcobrick wrote: 13 Mar 2019, 17:13 This morning I removed the brake pedal position sensor. I replaced it with one from an XC90 that had no ABS warnings. The problem has not gone away.
http://i.ebayimg.com/images/i/230922126 ... -l1000.jpg
Also, have you considered the possible failure or misadjustment of the brake light switch on the pedal itself? One of the codes you're getting refers to a correlation problem between the Brake Position Sensor and the Brake Light Switch.
Do your brake lights work? Does the Cruise control engage and disengage properly?
Marcobrick
Brake lights function normally. Cruise is disabled. I suspect the lack of correlation must be because the BCM is not correctly receiving and/or reporting brake signals.
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
Marcobrick
Can someone tell me if the ECM and TCM get their speed signals from different sources? I ask because my speedometer works correctly, the transmission works fine, but I have no speed signal on my live data on my CAN OBD reader...
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
- 1820 Views
Last post by Archieherm
- 44 Replies
- 17585 Views
- 1793 Views
Last post by CDoore54
- 1487 Views
Last post by T64me
- 11 Replies
- 8583 Views
Last post by ggleavitt
