Perhaps that shop fitted some NGK Iridium spark plugs which it seems have a hit and miss success rate according to recent posts: viewtopic.php?f=5&t=54863
Can you pull one of them to see? Would be interesting to see if they were properly gapped while you're in there. Too much anti-seize used causing arching and bad flame path? Some of the most basic maintenance items can be done poorly if they're in a hurry. Even an untorqued spark plug can cause major havoc.
Were Genuine coil packs used or at least Delphi which is OEM?
$6500 for repairs?
precopster
- Year and Model: Lots
- Been thanked: 128 times
- RickHaleParker
- Been thanked: 979 times
Considering what that shop cost, I got to ask: Do they serve the customer Gray Poupon?
Active
Past
Past
- June
- Has thanked: 523 times
- Been thanked: 261 times
I agree! The OP is paying dealership price without getting the Volvo lifetime warranty on repairs! So I would reconsider using a indy that cost that much, or use the dealer and have the lifetime parts and labor warranty as well as guaranteed genuine Volvo parts being used. If you're going to spend that kind of money on repairs, why not get the guarantee! JuneRickHaleParker wrote: 20 Mar 2019, 01:24 Considering what that shop cost, I got to ask: Do they serve the customer Gray Poupon?
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
Andy,
The 3.2 Liter 6 cylinder engine in your XC90 is a very dependable engine.
I like the design enough that i purchased two vehicles with the same engine (and I still own both vehicles)
I've owned my first 3.2 since 2008 (11 years)
During that time I've researched the typical things that go wrong and I've been proactively replacing based on the experience of others.
My recommendation is to replace the Thermostat.
This is a known failure point for the 3.2 and you are at the right mileage for the failure to occur.
And there is some evidence that the broken Thermostat can cause coil failure.
I have lots of links that I can share but I see that this is your third post and I don't want to overwhelm you with information.
The good news is that based on what I've read the XC90 has sufficient room in the engine bay that the Thermostat can be replaced without removing the intake manifold (This is not the case for the 3.2's that I own)
if you do have the Thermostat replaced then let us know if that clears the P0420 code.
If not I have additional suggestions for the P0420
Good luck
Paul
Good luck
Paul
AndyG
- Year and Model: 2011 XC90
- Has thanked: 16 times
Check engine light is back on and the same code (P0420 catalyst efficiency trouble) is coming up. I took it to a local shop and the mechanic says the new plugs/coils could be causing the catalyst to misinterpret the boosted power from new items, making the CEL come on. He suggested simply using a bottle of CataClean to see if that helps. Thoughts?
- pgill
Picture of the broken Thermostat on my 2010 S80
http://www.freel2.com/forum/topic33004.html
Note: this is from the Land Rover forum (the LR2 uses the Volvo 3.2)
Have fun
Paul
Have fun
Paul
precopster
Without pulling coils/plugs to see what they fitted (regular plugs or something fancy) and how they fitted them it's just a guessing game, though if this fails to find the problem it's still a guessing game.
The thermostat failure can affect the mixtures and make car run rich when cold; hence the codes. Blowing coil packs as a result is extremely unlikely.
Personally I would buy my own set of plugs/coilpacks and a thermostat and start over.
- pgill
Andy,
I posted this on another board but I thought you would give you some hope that there is light at the end of the tunnel (and I'm not talking about a train)
Copied from a post on Freel2
My neighbor drives a Toyota Pickup
His truck is >100,000 miles and a 2006 model year
Check engine light is on
P0420 Catalyst not operating properly
Full disclosure: He knows nothing about cars
I search the Evil Toyota Empire boards - nothing useful
Based on what Volvo did for the 3.2 and 3.0T I decided to try Denso Iridium TT plugs in his Toyota
I reset the MIL and he drove his truck for a week.
No more MIL and he passed the state required emissions check.
Maybe I should join the Toyota boards and let them know what I did.
No chance of that happening..............
If they wanted my help they should have bought something interesting like a Land Rover or a Volvo.
Let us know what you find out
Thanks
Paul
Thanks
Paul
- RickHaleParker
It can't hurt and it is possible there is crud from the misfiring causing the P0420.AndyG wrote: 20 Mar 2019, 16:13 He suggested simply using a bottle of CataClean to see if that helps. Thoughts?
If you do this, read the instructions on the bottle, do the math and get the mix ratio correct. I suggest taking it out on the Interstate for a long drive, say 150 miles. That way your get a steady flow of the cleaner, not the all over the map flow you get with stop and go driving.
Active
Past
Past
- 1864 Views
Last post by hermechanic
- 18 Replies
- 6157 Views
Last post by AlexBHughes
- 37 Replies
- 7229 Views
Last post by rgk
- 931 Views
Last post by misha
- 823 Views
Last post by 93Regina
