Went to start my 850 after the winter -- lights on on but no starter at all!
tardcart
- Year and Model: 96 850t. 93 940t
- Has thanked: 3 times
- Been thanked: 37 times
You did press the brake pedal before shifting? if so, the brake switch could be stuck. I think it also does the brake lights so see if they work. the cruise control brake switch is next to it.
- RickHaleParker
- Been thanked: 980 times
It went into hibernation and needed a rude awakening before it's faculties became fully functional.plumsmooth wrote: 30 May 2019, 15:06 Not sure what causes the shifter to occasionally get stuck in park?
Active
Past
Past
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
The shifter in my T5 was like that when I bought it, and it always needed the Manual Override button depressed to shift it out of Park.
Then one day, it decided to work properly, and I only need to use the Override button maybe once every 100 times.
Won't be an issue when I get the manual trans installed.
- 741 Views
Last post by Kyle123
- 883 Views
- 1240 Views
Last post by regent
- 936 Views
Last post by GreenMagicMan
- 1474 Views
Last post by davidcschulte
