XC90 remove rear strut
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Re: XC90 remove rear strut
Post by MoVolvos »
Thanks for the pictures and nice work. Good to know the hardened piston can be cut.
MnBoy
Year and Model: 2012 XC90
Post by MnBoy »
Just did mine. XC90 2012. Who ever would design this top nut and torx set-up is beyond me. It is a real pain. After trying to remove the rusted nut according to the standard methods, nothing worked. You have no room to work with and the nut is in the recess and difficult to access. You have to keep the torx stud from moving as you try to twist the nut off. Everything is full of rust and dirt. Frustration sets in. Somewhere I read that just drilling the bolt out is the best way to get this off. I totally agree. Get a drill bit just little smaller in diameter than the bolt stud with the torx 40 opening in it. Drill away the bolt stud until the18 mm nut can be twisted off easily. This takes no more than 5 minutes. Yes, it gets hot and leaves metal shavings...but it works.
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
A good impact wrench will take nut right off, but shit happens!!
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
