What Boost/Vacuum Gauge are you running?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
reverend
Year and Model: 2006 V70 2.5t
Has thanked: 2 times
Been thanked: 3 times
Re: What Boost/Vacuum Gauge are you running?
Post by reverend »
- Pete - wrote: 09 Sep 2019, 13:42 Looks good Reverend. Did you hook yours up so it’s dimmable?
At 14-15psi max you must be stage 1 I assume?
Thanks - it's rough and was my first ever attempt at fiberglass work. Yeah, it's dimmable, but I hooked it up to the hazard light button, so it's dim when it's on (enough to see at night though). The amusing part is that if I hit the hazard button, then the gauge flashes bright/off/bright/off. haha
I have the Polestar tune on mine.
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 80 times
Been thanked: 175 times
Post by - Pete - »
reverend wrote: 14 Sep 2019, 15:11
Well it turned out great, color matching looks excellent.
I've read where guys have wired to the hazard button. I've been considering doing what this guy did HERE.
I wasn't aware that Polestar offered tuning for these old cars, good to know. Pretty respectable "optimized" numbers.
Where does your boost peak at in 1st and 2nd?
Do they do it wirelessly? Or do you send in ECU/bring vehicle in?
I don't mean to be nosy, but what did the tune cost you?
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
reverend
Post by reverend »
- Pete - wrote: 14 Sep 2019, 21:20 Well it turned out great, color matching looks excellent.
Thanks. The color matching was done at Home Depot, I gave them my fuse box cover (side of the dash) to match to, then got a tiny $2 jar of "sample paint". Yeah, it's house interior paint, but it worked out ok.
Wiring it to the hazard light can be done, but then you'll have a pretty dim gauge. It'll flash bright/off with the hazards too. :D
You could probably find the source of the power to the bulb and tap that, or pull it from the LSM instead, and get it to dim with the gauge dimmer (also works if you do the R/Classic cluster swap).
Peak boost is around 14-15 per the gauge, not sure if that's in 1st or 2nd. In those gear I don't watch the gauge if I'm on it that hard. haha
I dropped my car at the dealer and they flash it and I think it cost me around $800 a few years ago. HUGE improvement, mostly in transmission tuning, imo.
I'm sure there are cheaper and higher performing tunes, but I needed reliability (start the car in Death Valley in the summer, and Alaska in the winter sort of stuff) and none of the other ones seem troublefree and THAT reliable, so Polestar it was.
Starbuck
Year and Model: 2004 XC70
Has thanked: 46 times
Been thanked: 9 times
Post by Starbuck »
reverend wrote: 09 Sep 2019, 12:55 I use a simple SunPro (probably Chinesium) gauge that seems to work ok. I really just want it as baseline info and see if it ever deviates. I don't see more than 14-15 psi when I romp on it.
I'm super late to this but a while ago I PM'd you asking about your build and you were kind enough to respond. I just wanted you to know I really appreciated it. This forum and you guys are the best!
2004 XC70 - "Benjamin Wash"
2008 XC90 3.2 - "Norman" (RIP totalled)
2004 S60R - "Nial" (Sold to a good home)
1991 Mazda Miata - "Origami"
1982 VW Rabbit Pickup - "Judy"
