I guess I also missed the "month ago" part. Yes, I would expect it to adjust by now, if it was possible.
I was going to suggest an R&R of the fittings again, but you also mentioned that priming the system multiple times before trying to start the car doesn't improve things, so it seemed moot.
Have you actually put a FP gauge on it yet to verify what's happening with the pressure?
Problems after fuel filter replacement
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
I have seen this a few times over the years. And it was with Volvo filters. The fuel pressure regulator gets a fibre in the seat and it leaks. The fuel drains out and there will still be air after one pump prime cycle and it takes the start n die cycle to purge the vapor. Take the line off the fuel presure regulator after yu shut off engine and see if it has a continual drip after the initial spill of fuel when line comes off. If you cycle key three times that usually will mostly fix it if this is the issue.
The speculation is that some loose filter media fibres get loose and wash off the new filter.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
M4.4 have small fpr near the fuel filter and have no clamps on the lines(from the factory)...i'm affraid that i will damage the lines and will not be able to put them back on fpr.
I'll post a picture later.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 1613 times
- Been thanked: 4078 times
It might be prudent to flush the filter with the first 100 ml of fuel. You need a helper but basically just put the filter onhalfway, out open end into a cup, then keyon for a few seconds
- misha
Too much hassle for little gain abscate.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 312 times
- Been thanked: 818 times
I agree with you to be vary careful about the hard lines. They are NLA and very difficult to remove without breaking things.misha wrote: 21 Sep 2019, 03:05 M4.4 have small fpr near the fuel filter and have no clamps on the lines(from the factory)...i'm affraid that i will damage the lines and will not be able to put them back on fpr.
M4.4 has the small FPR near the passenger wheel or by the fuel filter. Either one is the same FPR - you can access the line by unscrewing the little clamp and lifting the FPR out of the housing.
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
I have never heard about that. Thank you for that information.jimmy57 wrote: 20 Sep 2019, 19:39 I have seen this a few times over the years. And it was with Volvo filters. The fuel pressure regulator gets a fibre in the seat and it leaks. The fuel drains out and there will still be air after one pump prime cycle and it takes the start n die cycle to purge the vapor. Take the line off the fuel presure regulator after yu shut off engine and see if it has a continual drip after the initial spill of fuel when line comes off. If you cycle key three times that usually will mostly fix it if this is the issue.
BMW 540i 2002
S70 Base 2000
- misha
It's easier to start it on the 2nd try when it sits overnight than to brake the lines trying to fix the small issue.
Than that small issue becomes a HUGE issue since the parts involved are no longer available.
Don't you think so?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- kallekula
Abscate wrote that it might be a good idea to flush a new fuel filter first before you hook it up completely. I agree with that. I also believe there is little else hassle to ask a wife/buddy to turn the key for a few secs to flush the new filter using the vehicles pump as help. You are already crawling around in the dirt with rust in your eyes smelling like gas. There is little else hassle to do the flush. Am I right?misha wrote: 21 Sep 2019, 09:44It's easier to start it on the 2nd try when it sits overnight than to brake the lines trying to fix the small issue.
Don't you think so?
EDIT:
And the gain is huge. Avoiding some possible fibre/debree left from manufacturing enter the fuel system! HUGE!
EDIT2:
Who the hell wants a car that always starts on the second time after ditting overnight? It would drive me personally absolutely nuts. This is no problem you can accrpt and continue living with. It has yo be fixed.
BMW 540i 2002
S70 Base 2000
- 870 Views
Last post by alschnertz
- 20 Replies
- 13965 Views
Last post by oragex
- 742 Views
- 608 Views
Last post by jonesg
- 1572 Views
Last post by 93Regina
