Can a 5 bolt p80 REAR hub fit on the 93 850 4 bolt axle
You can just JB Weld the wheel to the hub....or zip tie the four holes to the five..
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Did you also replaced air valves on the rims?
They could leak air.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
abscate's creative imagination knows no limits—living in that neck of the woods, there's probably an Edisonian gene or two randomly distributed in the NY poolabscate wrote: 26 Oct 2019, 09:51 You can just JB Weld the wheel to the hub....or zip tie the four holes to the five..
Misha: I think the tech changes the stem when he grinds the rim, I'm sure he has in the past on other rims, maybe that one, too. They test for leaks using a spray solution of water with a dash of soap, so when it goes out the door, presumably it's leak-free. There should be a better goo that can fill even the minutest gaps.
- 1894 Views
Last post by Mikaro07
- 1892 Views
- 2392 Views
Last post by [email protected]
- 588 Views
- 1910 Views
