2010 XC60 tailgate won't stay up (goes up and down fine)
@aaronlife - were you able to get the issue resolved? I'm having a similar problem with my XC60. Dealer is quoting $600 to replace the left automatic arm and $1,100 to replace the pump. Any advice? As a last resort, could I replace the left automatic arm with a manual one (right version), and simply not use the automatic function? $1,100 is too much to invest in a 10+ year car. Thanks!
aaronlife
- Year and Model: 2010 Volvo XC60
- Has thanked: 1 time
- Been thanked: 2 times
Yes, the new arms didn’t help. I ordered a used pump from https://www.erievovo.com/ for $200-$250 (can’t recall) and swapped in my pump computer (that was different model # and they weren’t compatible I guess), and that solved it. The used pump has a lifetime warranty.
The issue seems to be a valve in the pump. You can test by removing the inside hatch cover and disconnect the hoses from the pump. The hoses have a valve that closes and keeps fluid/pressure in the lines. When I disconnected the hoses from the pump the hatch suddenly stayed up.
Had I started with that test I would not have replaced the two arms.
Any questions feel free to ask!
aaronlife
I got the right side cylinder from fcp euro, that was under $100, along with hydraulic fluid for the pump which I didn’t really need either.
The left cylinder I didn’t need was $300 new from oemvolvoparts.com
I suspect erie vovo has used left cylinders if it’s not your pump. They are also very familiar with the issue. If you give them both the pump and computer dare codes/part #s it can help.
miamiautohelp
- Year and Model: 2011 xc60
where did you find the pump?aaronlife wrote: 02 Mar 2020, 08:40 Swapped module on the new/used pump with my old module and the down button works fine now.
Issue with the pump must be the solenoid or one of the valves on top of the pump where the hose connects, because the tailgate stays up when the hoses are disconnected, so connecting the hoses releases the valve on the end of the hose, but the pump isn't holding the pressure.
- 836 Views
Last post by aaronlife
- 1924 Views
Last post by volvolugnut
- 19 Replies
- 32652 Views
Last post by Dzikiewicz
- 5769 Views
Last post by vtl
- 1132 Views
Last post by vtl
