2006 Volvo S60 2.5t code p0089
rjj100
- Year and Model: 2007 S60 2.5T
Regarding the connectors: you could ask your auto parts store if they sell the connector, or perhaps a salvage yard. I strongly advise crimped connections or better soldered and wrapped connections to the connector. Twisting wires together and wrapping with tape will NOT last. If the issue is the locking mechanism is broken, you could try a small zip tie to securely hold the connector onto the ignition coil.
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Are you saying your fuel pump is pushing out 60psi yet you have 0psi at the injector rail?
Is the pressure gauge connected properly to the schrader valve?
What happens if you hold a rag over the schrader valve and depress the center valve core? Does it spray fuel?
Pat007
- Year and Model: 2006 s60 2.5t
Thanks ima look at it over.and I’m ordering the fuel pressure sensor today I changed the spark plugs in coils packs yesterday and it run better it just wen I try go over 30 mph or 40 it started hesitating and running crazy any thoughts on that?
rjj100
Pat007: Where did you measure the 60 psi if not at the fuel rail and the schraeder valve? And, did you read all of my postings and understand them?
Did you reset the codes after replacing the spark plugs and ignition coils? What were the codes after you drove the car?
60 psi means your fuel pump is good! I would not replace it.
Pat007
Rjj100 yes I seen all the post and understand i think
and the guy n the shop already had the gauge hook up wen I came in to check on my car I’m not sure were he had it connected to but the reading from my pump was 60 pbi And once I changed the spark plugs and coils it had ease the misfire codes and run a little better then wat it did.and u saying don’t change the pump again ?its the pressure sensor cause I get toe lil gas and pressure from the fuel rail
rjj100
Pat007: You can ask your shop person, but I must assume he measured the pressure at the schraeder valve because that is where you measure the fuel pressure. Please confirm.
If you had 60 psi at the schraeder valve with the engine running you would have plenty of gas. How else did you determine you had too little gas and pressure?
- 1452 Views
Last post by SHOCKWAVE
- 2472 Views
Last post by bfry
- 589 Views
Last post by cn90
- 4594 Views
Last post by stickman776
- 1618 Views
