This is a good resource for Volvo wiring diagrams. Does not cover P80 or older:
https://volvodiag.com/ewd-online-eng/
Fuel Pump Relay Pin (Single Digit) Numbers
- Has thanked: 2196 times
- Been thanked: 1850 times
JDS60R
- Been thanked: 3 times
If its a micro relay ,The two larger blades 3 and 5 carry the current to the pump when closed by the coil.. When pulled from the fuse box one of slots should have power. The other is the wire to the pump. Jumping those 2 slots will make it run constant Diagram added
Terminal/Pin number and size
Connection
1 (86) - 4.8mm Coil
2 (85) - 4.8mm Coil
3 (30) - 6.3mm Common connection to NO & NC terminals
4 (87a) - 4.8mm Normally Closed (NC) - not present on 4 pin relays
5 (87) - 6.3mm Normally Open (NO)
Connection
1 (86) - 4.8mm Coil
2 (85) - 4.8mm Coil
- MIcro relay.jpg (5.18 KiB) Viewed 178 times
Retired
- 1224 Views
Last post by EstVolvo
- 974 Views
Last post by precopster
- 1087 Views
Last post by jonesg
- 16 Replies
- 12346 Views
Last post by Rgierer
- 5052 Views
Last post by wizechatmgr
