Check alternator output....just in case.
Besides J relays,alternator diodes could also fail in this case.
Issue after battery wrong connection...
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Go for a lottery ticket!
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
On your 96 the ABS light is probably triggered by a bad solder joint in the ABS module. The procedure to fix is quite easy: you basically cut the box open, resolder the pins, put it back together and seal the housing.
For a good writeup search the forum. Also, you need an E5 bit to remove the ABS module. Or a 4mm hex socket. The E5 is better, though I have removed mine a few times wirh the 4mm hex.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
