Well. It's not the FPS.
On to spark plugs.
Misfire at idle, occasionally low speeds. Lots of details
drmegadan
- Year and Model: 2004 V70 T5
- Has thanked: 5 times
Finally found some time yesterday. Pulled the plugs and did compression test. #4 plug came out with the insulator in many pieces. Hmm. The plug was tight so I'm not totally sure it didn't shatter when the plug popped loose; but I don't think that was the case.
Compression was 135-155 across all cylinders; car was warmish but not hot. Numbers are a tad low but not concerning. I had a set of the same plugs but in a 7 heat range (one step colder) sitting around from my 300zx and chose to drop those instead of swapping them from the other Volvo. A test drive yesterday showed no symptoms, as did a drive today to work. I'm going to give it a few days before I consider this issue resolved; as last time I made some changes things seemed good at first.
I'm finally getting a check engine light, but no codes are stored. Ugh. Going to clear it and see if it comes back; it reared its head when the misfire got much worse (due to broken plug?) I cleared it and it stayed away until I did the compression test which likely brought it back.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Try see if there is a bad coil anyway www.youtube.com/watch?v=fnYUQh23p7Q
Also look at the wires to the coils, then at the wires to the injectors. You may even want to remove the injectors and test them with a small 9v battery pushing distilled water - look at the shape of the spray (check Youtube)
As others said 43psi is too low for a turbo, it usually stays 55-60psi idle/driving. You may want to swap the PEM module if your spare car has one, and look at the fuel filter if it's external.
drmegadan
I don't believe I've specifically tested the coils; but I did swap them between vehicles and that didn't result in any change. Wiring to coils was crusty, but the wiring itself was intact.oragex wrote: 13 Apr 2020, 08:18 Try see if there is a bad coil anyway www.youtube.com/watch?v=fnYUQh23p7Q
Between my wife and myself we've put roughly 15 drive cycles and 400 miles on it without another CEL or hint of a misfire. I'm not going to concern myself TOO much with the fuel pressure as it was measured with torque (granted I trust those numbers in my other vehicles). I'll get a physical fuel pressure tester and check the rail at some point. Fuel filter was replaced by the owner before me (supposedly). I think I remember seeing it all shiny and new; so it's not a concern either.
For now I'm going to consider this issue resolved. Now I need to figure out where the occasional coolant smell is coming from. I'm losing 1/4" of coolant from the reservoir over 1000 miles or so. Darn. Thanks for all the help and suggestions getting me to this point.
- 3292 Views
Last post by rguzz
- 2845 Views
Last post by Oly850
- 3289 Views
Last post by FLXC90
- 1855 Views
Last post by Davwatermk
- 903 Views
Last post by 93Regina
