When you select pos 3 on the switch
Terminal 2 and 5 should connect with continuity
Terminal 1 and 3 should connect with continuity
You can use the beep function or ohms , lie scale to test those.
Wiper issue - no park, no intermittent sitting
- Has thanked: 1507 times
- Been thanked: 3822 times
Re: Wiper issue - no park, no intermittent sitting
- RickHaleParker
- Been thanked: 958 times
To test Cam switch:
1. Set multimeter to 20 volt range.
2. Place + lead on the wiper motor's green wire.
3. Place - lead on the wiper motor's yellow-violet wire.
4. Turn on the wipers.
You should see 0 Volts with one 12 Volt pulse per cycle of the wipers
- 1721 Views
- 2251 Views
Last post by MadeInJapan
