....and I nailed it today, working with wisechatmgr here in Albany
Short version, user error
The setup of the VVT was unamibiguous, but the timing procedure was not, in Alldata.
I locked the cams and did the VVT hub install correctly, one notch before mark.
I then timed it with the VVT hub clocked full clockwise.
This is wrong and puts you two notches advanced.
With 42 sprocket gears, each one is 360/42 = 8.6 cam degrees and thus 17.2 crank degrees.
The entire range of the reset valve (VVT solenoid and hub) is only +-20 degrees, so 2 teeth is way out of range.
I finally understood that the timing marks have to be set after the 1/2 crank past and return, so the VVT hub is clocked fully COUNTERCLOCKWISE.
Once I did this, My cam flanks came in at -16 degrees, roughly.
-16 degrees crank is one notch CAM, I retarded the VVT one notch, and the cam flanks all came in under 2 crank degrees.
P0014 ECM 644A cleared and the CEL stayed off.
1999 V70T5M56 timing belt job P0014 code, pernicious ECM 644A Topic is solved
Fixing this. This is in fact, cam retarded with respect to crank , not advancedhe limit position.
Continue turning clockwise until the timing gear pulley marking is 1 cog before the marking on the upper timing cover.
I retimed my T5 after the valve job and went through this exact same process, except this time this thread took the time on task to 5 minutes instead of 3 days
cjhusky
- Year and Model: 2001 Volvo S60 2.4T
@abscate, this thread has been very informative. I am extremely frustrated with my '01 2.4T. I recently did the entire PCV system, a timing belt and replaced the camshaft seals. I also changed the oil & filter, as well as the cap. I had thought I was extremely careful with the timing.
The vehicle starts, idles, and seemingly runs great. It ran for 40-50 miles with no CEL. However, after that the CEL came on. I read it as P0014 - Generic (Exhaust camshaft position timing - over advanced (Bank 1)).
So I reset the code and it ran for another 30 miles and same code.
I replaced the Camshaft Solenoid Adjuster (31355829 Exhaust Cam) and the gasket. Expensive part
Reset the code and it fired again after about 50 miles. Arrrrgggghhh.
When I replaced the timing belt, I held the VVT in fully clockwise position. It seems from what you're saying, that may be incorrect? I'm just at a loss here and don't want to throw anymore unnecessary money at this thing. And I certainly don't want to scarp the vehicle, but I'm beyond frustrated here. I'm also no where near as good as you at resetting timing and putting on timing belts.
What's the downside of driving on it with the advanced timing code? Need to still get around and its my only wheels, until I am of sound mind to give this another crack.
ANY advice happily accepted.
TIA
TIA
Correct. The belt needs to be installed with the VVT fully clocked counterclockwise and then one additional notch , in my experience
The p0014 code returns after the first restart after the cam code has been detected “ enough times” in software. The code isn’t “ showing up later” the root problem is always there , and the system just takes time to report it. The only way to really know it’s right at time of repair is to monitor cam flank angle. Covered up threads
I am back to fighting this again on the T5, except this time I am also getting an ECM-3000 code for a high cam signal voltage, permanent fault. AFter a day of fighting it, GeniusBoy figured out if the cam sensor signal isnt good, then the cam position will always code.
Cam sensor was good last year, so will dig in and check install, wiring, etc. Its a $250 part new, 1999-2000 only, so too expensive to parts cannon.
- Has thanked: 2199 times
Can you post a picture of the part or the part number so I can check the 'stash'.
scot850 wrote: 20 Sep 2023, 12:53 Can you post a picture of the part or the part number so I can check the 'stash'.
Part 9202134. It’s a bastard only part
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
Does the car still run with the sensor disconnected/bad? I got a roundabout 00 manual s70 Base that will never see a real road again unfortunately. I do not have an ETA of when i could reach the part but people on here have helped so i can throw my hat in for sending it. Car has 366k km on it last i checked. Hasnt been started in about 6-8 months :/.
Time waits for no one.
2008 S60 2.5T Auto (Sold)
- 18 Replies
- 2117 Views
Last post by dikidera
- 5245 Views
Last post by jimmy57
- 38 Replies
- 12335 Views
Last post by prwood
- 303 Replies
- 37310 Views
Last post by bmdubya1198
- 25 Replies
- 6809 Views
Last post by wizechatmgr
